BPI-BT BLE 4.2 control module
BPI-BT BLE 4.2 control module is a kind of maker product of wireless bluetooth intelligent control. It supports bluetooth BLE4.2 protocol. Through the connection of smart phone BLE bluetooth, it can control LED lights, N20 motor, micro-steering machine, relay, electromagnet and other low-voltage devices, which facilitates the makers to realize their creativity.
Hardware=
hardware spec:
| HardwareSpecification of BPi BC95-LINARO | |||
| name | parameter | explain | |
| operating frequency | 2.4G | ||
| operating voltage | 3.7~6V | It is recommended to use the 2A battery pack, or 4 section 5 dry batteries. | |
| operating temperature | -40℃ - 80℃ | ||
| transmission range 60米 | Open field data.Indoor transmission will be reduced. | ||
| bluetooth | BLE4.2 | ||
| size | 32mm x 35mm x 14mm | 3 M3 fixed holes are left, and the hole spacing is compatible with lego brick hole spacing, which is convenient to be fixed with M3 flat head screw. | |
