Description
The BPI-7402 series of modules are designed to extract power from a conventional twisted pair Category 5 Ethernet cable, conforming to the IEEE 802.3af and IEEE 802.3at Power-over-Ethernet(PoE) standard.it is 30W POE PD Module ( Isolation Model),The BPI-7402 signature and control circuit provides the PoE compatibility signature and power classification required by the Power Sourcing Equipment (PSE) before applying up to 30W power to the port.
The DC/DC converter operates over a wide input voltage range and provides a regulatedoutput. The DC/DC converter also has built-in short-circuit output protection.
Features
- IEEE802.3at and IEEE802.3af compliant
- Maximum 30W output power
- Low output ripple and noise
- Short-circuit protection
- Transformer isolation ,1000V isolation (input to output)
Applications
- IoT gateway
- IP Cameras
- Wireless access point
- Security and alarm systems
- VOIP telephone
PBI-7402 PoE Hardware
Module size
Pin Description
| BPI-7402 at PoE module | |||
| 5 | AT-DET+ | Internal rectifier bridge output + | |
| 6 | GND | Internal GND | |
| 7 | -VDC | DC Return. This pin is the return path for the +VDC output. | |
| 8 | -VDC | DC Return. This pin is the return path for the +VDC output. | |
| 9 | +VDC | DC Output. This pin provides the regulated output from the DC/DC converter. | |
| 10 | +VDC | DC Output. This pin provides the regulated output from the DC/DC converter. | |
DC Electrical Characteristics
Note
- 3: Continuous short circuit duration is applicable at 25'C ambient temperature in free air. At higher temperatures or with restricted
Absolute Maximum Ratings
| BPI-7402 PoE module | |||||
Note
- 1: With minimum load
