Banana Pi BPI-P2 Zero
Revision as of 19:11, 1 August 2018 by Sinovoip (talk | contribs) (Hardware spec)
Overview BPI-F2 Zero with Allwinner H2+ chip
Overview BPI-F2 zero PoE support
Banana Pi BPI-F2 Zero is an ultra compact single board computer measures only 65mm*52.5mm. It uses quad-core Cortex A7 allwinner H2+ processor(Option : H3 and H5), with 512MB RAM memory.8G eMMC flash,100M LAN,add PoE function support , It's ideal for light-weight systems with some space-limited applications. Like other members of Banana Pi, it supports both linux and android operating system.
  • 512MB DDR 3 SDRAM.
  • Mini HDMI.
  • 100M LAN
  • PoE function support
  • 8G eMMC flash onboard.
HardWare Specification of Banana pi BPI-M2 zero VS Raspberry Pi Zero W
Module Banana Pi BPI-F2 Zero Banana Pi BPI-M2 Zero Raspberry Pi Zero W
IR N/A N/A N/A
Product size 65mm × 30mm 65mm x 30mm
Weight 30g 15g 9g
