Banana Pi BPI-P2 Zero
Banana Pi BPI-F2 Zero is an ultra compact single board computer measures only 65mm*52.5mm. It uses quad-core Cortex A7 allwinner H2+ processor(Option : H3 and H5), with 512MB RAM memory.8G eMMC flash,100M LAN,add PoE function support , It's ideal for light-weight systems with some space-limited applications. Like other members of Banana Pi, it supports both linux and android operating system.
- 512MB DDR 3 SDRAM.
- Mini HDMI.
- 100M LAN
- PoE function support
- 8G eMMC flash onboard.
HardWare Specification of Banana pi BPI-M2 zero VS Raspberry Pi Zero W | |||
Module | Banana Pi BPI-F2 Zero | Banana Pi BPI-M2 Zero | Raspberry Pi Zero W |
IR | N/A | N/A | N/A |
Product size | 65mm × 30mm | 65mm x 30mm | |
Weight | 30g | 15g | 9g |
