Banana Pi BPI-P2 Zero
Revision as of 18:48, 1 August 2018 by Sinovoip (talk | contribs) (Created page with "=Introduction= thumb|Overview zero with Allwinner H2+ chip thumb|Overview zero with Allwinner H3 chip File:BPI-M2_zer...")
File:BPI-M2 zero.jpg
  • 512MB DDR 3 SDRAM.
  • Mini HDMI.
HardWare Specification of Banana pi BPI-M2 zero VS Raspberry Pi Zero W
Module Banana Pi BPI-M2 Zero Raspberry Pi Zero W
CPU H2+ Quad-core Cortex-A7 H265/HEVC 1080P Broadcom BCM2835 32 Bit 1 GHz ARM1176JZF-S single-core
GPU Mali400MP2 GPU @600MHz,Supports OpenGL ES 2.0 VideoCore IV
Memory \(SDRAM\) 512M DDR3(shared with GPU) 512 MB DDR2
Onboard Storage TF card \(Max. 64GB\) TF card \(Max. 64GB\)
Onboard Network NOPE (but can extension with PIN define) NOPE
Onboard WIFI SDIO AP6212(option AP6181、AP6335) 802.11n wireless, Bluetooth 4.1
Video decoding 1080p@60fps,H.264 Video encoding 1080p@30fps,H.264 1080p30 H.264/MPEG-4 AVC high-profile decoder and encoder
Video input A CSI input connector Camera CSI camera connector
Video Outputs mini HDMI 1.4,1080P@30fps, DHCP Mini HDMI and USB On-The-Go ports
Audio Output Mini HDMI Mini HDMI
Power Source Micro USB with 5V/2A 5V/2A
USB 2.0 Ports one USB 2.0 OTG one USB 2.0 OTG
Buttons Power Button, Reset Button Composite video and reset headers
Low-level peripherals 40 Pins Header,compatible with Raspberry Pi 3 40 PIN
uart GPIO\(1x3\) pin UART, ground UART
LED Power led & Status led Power Status LED
IR N/A N/A
Supported OS Android, Ubuntu, Debian, Rasberry Pi Image Linux
Product size 65mm × 30mm 65mm x 30mm
Weight 15g 9G
