Banana Pi BPI-F2
Overview:BPI-F2 with freescale IMX6
HardWare Specification of Banana pi BPI-F2
Soc with freescale IMX6
CPU
GPU
SDRAM
SATA support 1*SATA interface
Bluetooth BT4.0
On board Storage MicroSD \(TF\) card,No eMMC onboard
USB 4 USB 2.0 host, 1 USB 2.0 OTG
IR No onboard IR receiver
battery No 3.7V lithium battery power support
Weight 40g
