HardWare Specification of Banana pi BPI-F2
Soc |
with freescale IMX6
CPU |
GPU |
SDRAM |
SATA |
support 1*SATA interface
GPIO |
40 Pins Header, 28×GPIO, some of which can be used for specific functions including UART, I2C, SPI, PWM, I2S.
On board Network |
10/100/1000Mbps Ethernet \(Realtek RTL8211E/D\)
Wifi Module |
WiFi 802.11 b/g/n \(AP 6212 module on board\)
Bluetooth |
BT4.0
On board Storage |
MicroSD \(TF\) card,No eMMC onboard
Display |
4-lane MIPI DSI display,or RGB panel or LVDS panel,TV-out on HDMI V1.4
Video |
Multi-format FHD video decoding, including Mpeg1/2, Mpeg4, H.263, H.264, etc H.264 decode up to 1080P60,support video encodeing:High-deinition\(HD\)H.264 video encoder is up to 1080P@45fps
Audio outputs |
HDMI, analog audio \(via 3.5 mm TRRS jack\), I2S audio \(also potentially for audio input\)
Camera |
A CSI input connector Camera:Supports 8-bit YUV422 CMOS sensor interface,Supports CCIR656 protocol for NTSC and PAL,Supports 5M pixel camera sensor ,Supports video capture solution up to 1080p@30fps
Audio input |
On board microphone
USB |
4 USB 2.0 host, 1 USB 2.0 OTG
Buttons |
Reset button, Power button, U-boot button
Leds |
Power status Led and RJ45 Led
IR |
No onboard IR receiver
DC Power |
5V/2A with micro USB port
battery |
No 3.7V lithium battery power support
Sizes |
85mmX56mm,same size as raspberry pi 3
Weight |
40g
