Getting Started with M2P
- 1 Introduction
- 2 Development For Android
- 3 Development For Linux
- 4 Reference Link
BPI-M2+ H3
- 1GB DDR3
- 8GB eMMC onboard
- WiFi and BlueTooth onboard
Load your first image on M2P
* Here is the example of M3![]()
Load your image on M2P EMMC
1.The only different with sd card burning is the image burning mode item choice
* Here is the example of M32.After succeed to burn image to SD, then plug SD card in your M2P 3.Press power button, device will copy image to EMMC automatically
1.You could download latest image from our forum * Here is the example forum thread link: http://forum.banana-pi.org/t/banana-pi-bpi-m2p-new-image-release-ubuntu-16-04-v1-1/5719 2.Install bpi-tools on your Ubuntu * apt-get install pv * curl -sL https://github.com/BPI-SINOVOIP/bpi-tools/raw/master/bpi-tools | sudo -E bash 3.After you download the image, insert your TF card into your Ubuntu * Execute "bpi-copy xxx.img /dev/sdx" to install image on your TF card. 4.After step 3, then you can insert your TF card into M2P, and press power button setup M2P.
Load your first image on M2P EMMC
How to build uboot & kernel
Install tools
- apt-get udpate
- apt-get install pv
Clone code
- ./build.sh
How to create an image
OTG
1. On M2P console:
2. On PC terminal:
- Use iperf3 to test gmac
- Execute "bluetoothctl"
- Execute these commands:
WiFi on M2P
Driver code:
We use HDF5640 camara.
IR function
- Execute "getevent"
BPI-Tools
Install Bpi-tools
Update Bpi-tools
- Execute "bpi-tools"
- cd /usr/local/bin
How to Update WiringPi
