Getting Started with M2 Zero
BPI-M2 Zero
- Read more about : Banana Pi BPI-ZERO
- 512MB SDRAM.
- Mini HDMI.
* Prepare 8G/above TF card, USB-Serial interface, PC with Ubuntu System * Using your USB-Serial Connect debug console on M2 Zero
Load your first image on M2 Zero
1.You could download latest image from our forum 2.Install bpi-tools on your system * apt-get install pv * curl -sL https://github.com/BPI-SINOVOIP/bpi-tools/raw/master/bpi-tools | sudo -E bash 3.After you download the image, insert your TF card into your Ubuntu * Execute "bpi-copy xxx.img /dev/sdx" to install image on your TF card. 4.After step 3, then you can insert your TF card into M2 Zero, and press power button setup M2 Zero
How to create an image
OTG
1. On M2 Zero console:
2. On PC terminal:
USB Ethernet
- Use iperf3 to test network
- Execute "bluetoothctl"
- Execute these commands:
We use HDF5640 camara.
WringPi
