Banana Pi BPI-M2+
Revision as of 22:33, 6 May 2018 by Sinovoip (talk | contribs) (Hardware spec)
Banana Pi M2+(Plus)
Onboard Network 10/100/1000 Ethernet
Onboard WIFI SDIO AP6212(option AP6181 AP6335)
Audio Outputs HDMI
Power Source DC input can supply power, but USB OTG input don’t supply power
LED Power led & Status led
IR IR input on board
Opnewrt
TinaLinux
Release
