Banana Pi BPI-M2+
Banana Pi M2+(Plus) | |
CPU | H3 Quad-core Cortex-A7 H.265/HEVC 4K |
GPU | Mali400MP2 GPU @600 MHz,Supports OpenGL ES 2.0 |
Memory | 1GB DDR3 (shared with GPU) |
Onboard Network | 10/100/1000 Ethernet |
Onboard WIFI | SDIO AP6212(option AP6181 AP6335) |
Video Input | A CSI input connector Camera:1 Supports 8-bit YUV422 CMOS sensor interface,2 Supports CCIR656 protocol for NTSC and PAL, 3 Supports SM pixel camera sensor, 4 Supports video capture solution up to 1080p@30fps |
Video Outputs | Supports HDMI output with HDCP, Supports HDMI CEC, Supports HDMI 30 function, Integrated CVBS, Supports simultaneous output of HDMI and CVBS |
Audio Outputs | HDMI |
Power Source | DC input can supply power, but USB OTG input don’t supply power |
USB 2.0 ports | two USB 2.0 HOST, one USB 2.0 OTG |
GPIO | 40 Pins Header,compatible with Raspberry Pi B+ |
LED | Power led & Status led |
IR | IR input on board |
OS | Android, Ubuntu, Debian, Raspberry Pi Image |
Opnewrt
TinaLinux
