Banana Pi BPI-R2
Revision as of 19:50, 6 May 2018 by Sinovoip (talk | contribs) (BPI-R2 GPIO Pin define)
  • Mali 450 MP4 GPU
  • 2G DDR3 SDRAM
  • Mini PCIE interface.
  • support 2 SATA interface
Hardware Revision
Banana Pi R2
CPU MediaTek MT7623N, Quad-code ARM Cortex-A7
GPU Mali 450 MP4 GPU
Memory 2G DDR3 SDRAM
Storage On Board 8GB eMMC Flash, Micro SD-Card slot, Two SATA 2.0 Port (USB-to-SATA bridge)
Network 10/100/1000 Mbit/s Ethernet (MT7530) + Wi-Fi 802.11 b/g/n 2.4G/5G (MT6625L) + Bluetooth BT4.1 with MTK6625L chip
Audio Output(s) HDMI & I2S
USB ports USB 3.0 PORT (x2), USB OTG (x1)
PCIE 1 pcie interface & 1 pcie pin define interface
Remote IR Receiver (x1)
LED Power Status and 8P8C
BPI-R2 40 PIN GPIO define:
CON1-P02 VCC-5V
CON1-P03 GPIO75
CON1-P04 VCC-5V
CON1-P05 GPIO76
CON1-P07 GPIO206
CON1-P08 GPIO80
CON1-P10 GPIO81
CON1-P11 GPIO80
CON1-P12 GPIO74
CON1-P13 GPIO79
CON1-P15 GPIO205
CON1-P16 GPIO25
CON1-P18 GPIO24
CON1-P19 GPIO56
CON1-P21 SPI0\_MI GPIO55
CON1-P22 PCM\_CLK GPIO18
CON1-P23 SPI0\_CK GPIO54
CON1-P24 SPI0\_CSN GPIO53
CON1-P26 PCM\_RX GPIO20
CON1-P27 I2C\_SDA1 GPIO57
CON1-P28 I2C\_SCL1 GPIO58
CON1-P29 PCM\_RST GPIO22
CON1-P31 SPDIF\_OUT GPIO200
CON1-P32 PCM\_TX GPIO21
CON1-P33 I2S0\_MCLK GPIO126
CON1-P35 GPIO73
CON1-P36 GPIO19
CON1-P37 GPIO202
CON1-P38 GPIO72
Kernel 4.14
Kernel 4.4
OpenWrt
Kernel 4.9
