BPI-Bit
Revision as of 00:14, 5 May 2018 by Sinovoip (talk | contribs)
BPI:bit for Webduino & Arduino
Template:Use dmy dates Template:Infobox computer
The BPI Bit (also referred to as BPI:bit, stylised as webduino:bit) is an ESP32 with Xtensa 32bit LX6 single/dual-core processor based embedded system
The board is Template:Nowrap and has an ESP32 module with Xtensa 32bit LX6 single/dual-core processor, with a capacity of up to 600DMIPS, with a built-in 448KB ROM and 520 KB SRAM.accelerometer and magnetometer sensors,2.4G WiFI,Bluetooth and USB connectivity, a display consisting of 25 LEDs, two programmable buttons, and can be powered by either USB or an external battery pack.The device inputs and outputs are through five ring connectors that are part of the 23-pin edge connector.
BPI:bit interface:
File:BPI bit interfact.jpg
Template:Primary sources
