Getting Started with M2P
Revision as of 00:30, 30 June 2018 by JackZengWiki (talk | contribs) (→Load your image on M2P EMMC)
[hide]- 1 Introduction
- 2 Development For Android
- 3 Development For Linux
- 4 Reference Link
BPI-M2+ H3
- 1GB DDR3
- 8GB eMMC onboard
- WiFi and BlueTooth onboard
Load your first image on M2P
1.You could download latest image from our forum. Ex: http://forum.banana-pi.org/t/bananapi-bpi-m2p-h3-new-image-android7-0-release-2018-6-30/6147 2.Put your TF card into a TF-USB adapter, and then plug adapter in your Windows PC usb interface. 3.Prepare your image, and download image burning tools PhoenixCard.exe. 4.Use "PhoenixCard.exe" to burn android image to TF card.![]()
1.The only different with sd card burning is the image burning mode item choice
* Here is the example of M32.After succeed to burn image to SD, then plug SD card in your M2P 3.Press power button, device will copy image to EMMC automatically
1.You could download latest image from our forum * Here is the example forum thread link: http://forum.banana-pi.org/t/banana-pi-bpi-m2p-new-image-release-ubuntu-16-04-v1-1/5719 2.Install bpi-tools on your Ubuntu * apt-get install pv * curl -sL https://github.com/BPI-SINOVOIP/bpi-tools/raw/master/bpi-tools | sudo -E bash 3.After you download the image, insert your TF card into your Ubuntu * Execute "bpi-copy xxx.img /dev/sdx" to install image on your TF card. 4.After step 3, then you can insert your TF card into M2P, and press power button setup M2P.
Load your first image on M2P EMMC
How to build uboot & kernel
Install tools
- apt-get udpate
- apt-get install pv
Clone code
- ./build.sh
How to create an image
OTG
1. On M2P console:
2. On PC terminal:
- Use iperf3 to test gmac
- Execute "bluetoothctl"
- Execute these commands:
WiFi on M2P
Driver code:
We use HDF5640 camara.
IR function
- Execute "getevent"
WringPi
