BPI-PC101 gesture recognition module
- Digital control and data output via I2C (100 KHz and 400 KHz) interface
- ALS, PS and Gesture sensor with built-in IR LED
- Slave Address 0x58
- 6D Gesture Recognition Distance: 20~200 mm(up、down、left、right、hold)
- Programmable interrupt function for ALS and PS with upper and lower thresholds
- Support interrupt notification
Applications
- smart lights
- Household electrical control
- Music control equipment
- Game equipment
- Smart bath
- Distance detection
- Smart toy
Interface
Block Diagram
PC101 DFN Pin Assignment
PC101 PIN definitions
| PC101 Gesture Sensor Pin define | |||
| Pin | Name | Description | |
| 1 | 5V | Power | |
| 2 | GND | Ground | |
| 3 | INT | Digital Out | |
| 4 | SCL | Serial Digital Input Clock | |
| 5 | SDA | Serial Digital I/O Data | |
| 6 | TXD | Serial port sends pins | |
| 7 | RXD | The serial port receives the pin | |
Application Circuit
Electrical Characteristics
- Voltage characteristic
| Voltage characteristic | |||||
| No | pin | MIN | TYP | MAX | UNIT |
| 1 | 5V | 4.5 | 5.0 | 5.5 | V |
| 2 | GND | -0.3 | 0 | 0.3 | V |
| 3 | INT | GND | 0/3.3 | 3.7 | V |
| 4 | SCL | -0.3 | 0/3.3 | 3.7 | V |
| 5 | SDA | -0.3 | 0/3.3 | 3.7 | V |
- Digital interface characteristics
| Digital interface characteristics | |||||
| No | Description | MIN | TYP | MAX | UNIT |
| 1 | SCL/SDA:LOW | -0.3 | - | 1.0 | V |
| 2 | SCL/SDA:HIGH | 2.3 | - | 3.6 | V |
| 3 | SCL | 0 | - | 400 | kHz |
| 4 | Pull-up resistors | - | 2.0 | - | kΩ |
| 5 | INT:LOW | - | - | 0.4 | V |
| 6 | INT:HIGH | 2.4 | - | - | V |
I2C interface
| I2C interface ' | |||
| Ordering Chip Information | Write to Slave | Read from Slave | |
| PC101 | 1011000 | 1011001 | |
- Receive (Single Read) data from register
- Send (Single Write) data into register
Principles of Operation
Total register addresses are maintained inside the I2C block, each having a 8-bit register address. Each address accommodates an 8-bit data register that can be either written or read via I2C. The command registers program the sensor for various modes, setting and Interrupt threshold. The read-only registers contains output codes.
- Register Table and Definitions
| Register Table and Definitions | ||||
| NAME | R/W | 8-bit Address | Default | Descrition |
| ChipID | R | 0x00 | 0xAA | Chip ID |
| Capability | R | 0x01 | 0xF0 | Gesture Functional description |
| LibVersion | R | 0x02 | 0xB1 | Gesture Version |
| Gesture | R | 0x03 | 0x00 | Gesture Data |
| Proximity | R | 0x04 | 0x00 | Distance |
- 0x00: ChipID
This address holds ChipID, which is 0xAA by default and can be read to verify that I2C reading is normal.
- 0x01: Capability
This address holds a bitmap of the gesture detection capability, 0 Disable, 1 enable.
| Digital interface characteristics | ||||||||
| BIT | 7 | 6 | 5 | 4 | 3 | 2 | 1 | 0 |
| Read | Proximity | Hold | Left/Right | Up/Down | Reserved | Reserved | Reserved | Reserved |
| Reset | 1 | 1 | 1 | 1 | 0 | 0 | 0 | 0 |
The default is all supported, so the register defaults is 0xF0.
- 0x02: LibVersion
This address holds Gesture Version defaults is 0xB1.
- 0x03: Gesture Date
The address is stored with the result of gesture detection.
| address of gesture detection | |||
| 0: | Gesture(Hold) | 0xA0 | |
| 1: | Gesture(Up) | 0xA1 | |
| 2: | Gesture(Down) | 0xA2 | |
| 3: | Gesture(Left) | 0xA3 | |
| 4: | Gesture(Right) | 0xA4 | |
- 0x04: Proximity Date
This address holds the distance of the gesture from 0 to 255, the larger is near, the smaller is far.
How to Start
Use Uart
Connect product like the Circuit diagram , Set the Baud Rate as 115200
Using TTL-USB moudle, you can see the data like the picture
Use I2C
Set the SlaveAddress as 0x58,
Read Register 0x00, and result is 0xAA.
So, the I2C communicate success.
Plan one : Polling
Every 100ms read once gesture data.
Read Register 0x03, and result is Gesture data.
