BPI-PC101 gesture recognition module
- Digital control and data output via I2C (100 KHz and 400 KHz) interface
- ALS, PS and Gesture sensor with built-in IR LED
- Slave Address 0x58
- 6D Gesture Recognition Distance: 20~200 mm(up、down、left、right、hold)
- Programmable interrupt function for ALS and PS with upper and lower thresholds
- Support interrupt notification
Applications
- smart lights
- Household electrical control
- Music control equipment
- Game equipment
- Smart bath
- Distance detection
- Smart toy
Interface
Block Diagram
PC101 DFN Pin Assignment
PC101 PIN definitions
PC101 Gesture Sensor Pin define | |||
Pin | Name | Description | |
1 | 5V | Power | |
2 | GND | Ground | |
3 | INT | Digital Out | |
4 | SCL | Serial Digital Input Clock | |
5 | SDA | Serial Digital I/O Data | |
6 | TXD | Serial port sends pins | |
7 | RXD | The serial port receives the pin |
Application Circuit
Electrical Characteristics
- Voltage characteristic
Voltage characteristic | |||||
No | pin | MIN | TYP | MAX | UNIT |
1 | 5V | 4.5 | 5.0 | 5.5 | V |
2 | GND | -0.3 | 0 | 0.3 | V |
3 | INT | GND | 0/3.3 | 3.7 | V |
4 | SCL | -0.3 | 0/3.3 | 3.7 | V |
5 | SDA | -0.3 | 0/3.3 | 3.7 | V |
- Digital interface characteristics
Digital interface characteristics | |||||
No | Description | MIN | TYP | MAX | UNIT |
1 | SCL/SDA:LOW | -0.3 | - | 1.0 | V |
2 | SCL/SDA:HIGH | 2.3 | - | 3.6 | V |
3 | SCL | 0 | - | 400 | kHz |
4 | Pull-up resistors | - | 2.0 | - | kΩ |
5 | INT:LOW | - | - | 0.4 | V |
6 | INT:HIGH | 2.4 | - | - | V |
I2C interface
I2C interface ' | |||
Ordering Chip Information | Write to Slave | Read from Slave | |
PC101 | 1011000 | 1011001 |
- Receive (Single Read) data from register
- Send (Single Write) data into register
Principles of Operation
Total register addresses are maintained inside the I2C block, each having a 8-bit register address. Each address accommodates an 8-bit data register that can be either written or read via I2C. The command registers program the sensor for various modes, setting and Interrupt threshold. The read-only registers contains output codes.
- Register Table and Definitions
Register Table and Definitions | ||||
NAME | R/W | 8-bit Address | Default | Descrition |
ChipID | R | 0x00 | 0xAA | Chip ID |
Capability | R | 0x01 | 0xF0 | Gesture Functional description |
LibVersion | R | 0x02 | 0xB1 | Gesture Version |
Gesture | R | 0x03 | 0x00 | Gesture Data |
Proximity | R | 0x04 | 0x00 | Distance |
- 0x00: ChipID
This address holds ChipID, which is 0xAA by default and can be read to verify that I2C reading is normal.
- 0x01: Capability
This address holds a bitmap of the gesture detection capability, 0 Disable, 1 enable.
Digital interface characteristics | ||||||||
BIT | 7 | 6 | 5 | 4 | 3 | 2 | 1 | 0 |
Read | Proximity | Hold | Left/Right | Up/Down | Reserved | Reserved | Reserved | Reserved |
Reset | 1 | 1 | 1 | 1 | 0 | 0 | 0 | 0 |
The default is all supported, so the register defaults is 0xF0.
- 0x02: LibVersion
This address holds Gesture Version defaults is 0xB1.
- 0x03: Gesture Date
The address is stored with the result of gesture detection. 0: Gesture(Hold) 0xA0 1: Gesture(Up) 0xA1 2: Gesture(Down) 0xA2 3: Gesture(Left) 0xA3 4: Gesture(Right) 0xA4
