Getting Started with R2
Revision as of 19:07, 6 May 2018 by JackZengWiki (talk | contribs) (=Make your own image)
  • Mali 450 MP4 GPU
  • 2G DDR3 SDRAM
  • Mini PCIE interface
  • SATA interface
 1.Prepare 16G/above TF card, USB-Serial interface, Ubuntu System
 2.Using your USB-Serial Connect debug console on R2
Load your first image on R2
 * apt-get install pv
Build your own image on R2
 Execute "git clone [email protected]:BPI-SINOVOIP/BPI-R2-bsp.git"
OpenWrt
Develop 4G module with R2
Wifi and Ap mode on R2
Make your own image
Reference Link
