Banana Pi BPI-M1
Revision as of 08:10, 5 May 2018 by Sinovoip (talk | contribs)
Banana Pi BPI-M1
Template:Infobox computer The Banana Pi M1 is a business card-sized and low-power single-board computer featuring a high performance AllWinner dual-core SoC at 1 GHz, 1GB of DDR3 SDRAM, Gigabit Ethernet, SATA, USB, and HDMI connections. It can run a variety of operating systems including Android, Lubuntu, Ubuntu, Debian, and Raspbian.
Banana Pi M1
Memory 1GB DDR3
LED Power Key & 8P8C
Storage SATA 2.0,
The Banana Pi M1 Board detailed document on Banana Pi M1 Gitbook Page
Neither Banana Pi nor Shenzhen SINOVOIP Co.,Ltd. have a direct relationship to the Raspberry Pi Foundation, though its similarities are clear.<ref>Template:Cite news</ref> "Linux User & Developer" does not consider it a "direct clone, but a considerable evolution," whilst linux.com similarly sees it as a clone with improved performance.<ref>Template:Cite web</ref><ref>Template:Cite news</ref> The board layout is very similar to the Raspberry Pi board, though it's about 10% larger and the relative spacing of some connectors varies. Not all Raspberry Pi accessories will fit as a result.
