Banana Pi Series Comparison
Revision as of 06:26, 3 June 2018 by Sinovoip (talk | contribs)
Banana Pi Single board computer Comparison
module Banana Pi BPI-M1 Banana Pi BPI-M1+ Banana Pi BPI-M2+ Banana Pi BPI-ZERO Banana Pi BPI-M2M Banana Pi BPI-M2 Berry Banana Pi BPI-M2U Banana Pi BPI-M3 Banana Pi BPI-M64 Banana Pi BPI-S64 Core Banana Pi BPI-F2
Allwinner A20
Allwnner A20
Awinner H3
Allwinner H2+ same size as RPI Zero W
Allwinner R16/A33
Allwinner R40/V40 same size as RPI 3
Allwinner R40/V40
Allwinner A83T
Allwinner A64
BPI-S64 Core Actions S700
in progress
CPU A20,32 Bit Cortex™-A7 Dual-Core A20,32 Bit Cortex™-A7 Dual-Core H3,32 Bit Cortex™-A7 Quad-Core H2+,32 Bit Cortex™-A7 Quad-Core A33/R16,32 Bit Cortex™-A7 Quad-Core R40/V40,32 Bit Cortex™-A7 Quad-Core R40/V40,32 Bit Cortex™-A7 Quad-Core A83T,32 Bit Cortex™-A7  Octa-Core A64, 64 Bit Cortex A53 Quad Core Actions SOC S700,ARM Cortex-A53 Quad-Core CPU
GPU ARM® Mali400MP2 ARM® Mali400MP2 ARM® Mali400MP2 ARM® Mali400MP2 ARM® Mali400MP2 ARM® Mali400MP2 ARM® Mali400MP2 PowerVR SGX544MP2 GPU ARM® Mali400MP2 Mali450 MP4 GPU ,OpenGL ES2.0/1.1 OpenVG 1.1 EGL 1.5
Memory \(SDRAM\) 1G (shared with GPU) 1G (shared with GPU) 1G (shared with GPU) 512M(shared with GPU) 512(shared with GPU) 1G (shared with GPU) 2G (shared with GPU) 2G (shared with GPU) 2G (shared with GPU) 2GB LPDDR3
Onboard Storage SD (Max. 32GB)/MMC card slot SATA 2.0 port via SOC SD (Max. 32GB)/MMC card slot SATA 2.0 port via SOC MicroSD(TF) card /MMC card slot eMMC 8GB MicroSD(TF) card /MMC card slot MicroSD(TF) card /MMC card slot eMMC 8GB(option) MicroSD (TF) card / MMC card slot  eMMC 8GB SATA 2.0 port via USB MicroSD (TF) card / MMC card slot eMMC 8GB MicroSD(TF) card /MMC card slot SATA 2.0 port via SOC MicroSD(TF) card /MMC card slot SATA 2.0 port via SOC eMMC 8GB eMMC8GB
Network 10/100/1000 Ethernet 10/100/1000 Ethernet 10/100/1000 Ethernet NOPE NOPE 10/100/1000 Ethernet 10/100/1000 Ethernet 10/100/1000 Ethernet 10/100/1000 Ethernet
Onboard WIFI &BT NOPE 802.11b/g/n 802.11b/g/n & BT4.0 802.11b/g/n & BT4.0 802.11b/g/n & BT4.0 802.11b/g/n & BT4.0 802.11b/g/n & BT4.0 802.11b/g/n & BT4.0 802.11b/g/n & BT4.0
Display HDMI, CVBS , LVDS/RGB HDMI, CVBS , LVDS/RGB HDMI mini HDMI MIPI/LVDS HDMI, MIPI HDMI, MIPI HDMI, MIPI HDMI, MIPI
Camera Parallel 8-bit camera interface Parallel 8-bit camera interface Parallel 8-bit camera interface Parallel 8-bit camera interface Parallel 8-bit camera interface Parallel 8-bit camera interface Parallel 8-bit camera interface Parallel 8-bit camera interface MIPI Camera serial Interface(CSI) Parallel 8-bit camera interface
Video Outputs HDMI 1.4@1920*1080P LVDS/Sync RGB/CPU LCD interface up to 1920x1200 Video decoding speed up to 1080p@60fps Video encoding H.264 HP up to 1080p@30fps HDMI 1.4@1920*1080P LVDS/Sync RGB/CPU LCD interface up to 1920x1200 Video decoding speed up to 1080p@60fps Video encoding H.264 HP up to 1080p@30fps HDMI 1.4 1080p@60fps Support H.265 decode by 4K@30fps, support H.264 video encoding up to 1080p@30fps HDMI 1.4 1080p@60fps,Support H.264 video encoding up to 1080p@30fps Decoding up to 1920x1080@60fps H.264 HP video encoding up to 1920x1080@60fps HDMI 1.4 1080p@60fps MIPI LCD interface up to 1920x1080 Decoding up to 1920x1080@60fps Video encoding H.264 HP: speed up 1920x1080@30fps HDMI 1.4 1080p@60fps MIPI LCD interface up to 1920x1080 Decoding up to 1920x1080@60fps Video encoding H.264 HP: speed up 1920x1080@30fps HDMI 1.4 HEVC/H.265 decoder(SW), Main profile, 1080p@30fps H.264 video encoding up to 1080p@60fps, 720p@120fps HDMI 1.4 Multi-format FHD video decoding, including Mpeg1/2, Mpeg4, H.263, H.264, etc H.264 decode up to 1080P60,H.265 decode up to 4KP30
Audio Output 3.5 mm Jack and HDMI 3.5 mm Jack and HDMI HDMI mini HDMI 4ohm/2.5W Speaker(2 Pin Hole) 3.5 mm Jack and HDMI 3.5 mm Jack and HDMI 3.5 mm Jack and HDMI 3.5 mm Jack and HDMI
Audino In Microphone Microphone NOPE Microphone Microphone Microphone Microphone Microphone Microphone
GPIO 26-PIN: GPIO, UART, I²C bus, SPI bus with two chip selects, CAN bus,PWM,+3.3 V, +5 V, ground 40-PIN: GPIO, UART, I²C bus,I²S bus,SPI bus with two chip selects, CAN bus, PWM,+3.3 V, +5 V, ground 40-PIN: PWM,GPIO,UART,I²C bus,I²S bus,SPI bus,+3.3v,+5v,ground. 40-PIN: PWM,GPIO,UART,I²C bus,I²S bus,SPI bus,+3.3v,+5v,ground. 40-PIN: PWM,GPIO,UART,I²C bus,I²S bus,SPI bus,+3.3v,+5v,ground. 40-PIN: PWM,GPIO,UART,I²C bus,I²S bus,SPI bus,+3.3v,+5v,ground. 40-PIN: PWM,GPIO,UART,I²C bus,I²S bus,SPI bus,+3.3v,+5v,ground. 40-PIN: PWM,GPIO,UART,I²C bus,I²S bus,SPI bus,+3.3v,+5v,ground. 40-PIN: PWM,GPIO,UART,I²C bus,I²S bus,SPI bus,+3.3v,+5v,ground.
Remote IR reciever IR reciever IR reciever NOPE NOPE IR reciever IR reciever IR reciever IR reciever
USB 2.0 Ports 2 USB ports, 1 OTG microUSB port 2 USB ports, 1 OTG microUSB port 2 USB ports, 1 OTG microUSB por 1 USB 2.0 OTG 1 USB 2.0 ports, 1 OTG microUSB port 4 USB ports, 1 OTG microUSB port 2 USB ports, 1 OTG microUSB port 2 USB ports, 1 OTG microUSB port 2 USB ports, 1 OTG microUSB port
Buttons Reset button, Power button, Uboot button Reset button, Power button, Uboot button Reset button, Power button, Uboot button Reset button, Power button, Uboot button Power button, Uboot button Reset button, Power button, Uboot button Reset button, Power button, Uboot button Reset button, Power button, Uboot button Reset button, Power button, Uboot button
LED Power LED (red), RJ45 LED (blue), user define LED (green) Power LED (red), RJ45 LED (blue), user define LED (green) Power LED (red,Can be defined by user) Power led Status led User define LED (red/power, blue, green) User define LED (red/power, blue, green) User define LED (red/power, blue, green) User define LED (red/power, blue, green) User define LED (red/power, blue, green)
Power 5V/2A via MicroUSB and/or MicroUSB (OTG) 5V/2A via MicroUSB and/or MicroUSB (OTG) 5V/2A via DC in and/or MicroUSB (OTG) 5V/2A via MicroUSB 5V/2A via DC in and/or MicroUSB (OTG) 5V/2Avia MicroUSB and/or MicroUSB (OTG) 5V/2A via DC in and/or MicroUSB (OTG) 5V/2A via DC in and/or MicroUSB (OTG) 5V/2A via DC in and/or MicroUSB (OTG)
Board Size 92mm×60mm 92mm×60mm 65mm×65mm 65mm×30mm 51mm×51mm 85mm x 55mm 92mm×60mm 92mm×60mm 92mm×60mm
