Banana Pi BPI-S64 Core
BPI-S64 Core with Actions S700
BPI-S64 Core front and back
BPI-S64 Core Kit
Banana Pi BPI-S64 core use Actions SOC S700 design. S700 chip with ARM Cortex-A53 Quad-Core CPU,Mali450 MP4 GPU. BPI-S64 core with 2G LPDDR3 and 8G eMMC flash onboard.
BPI-S64 core modules are small enough to fit all kinds of hardware.In addition,S64 core also provides I/O boards with GPIO ports, as well as USB, MicroUSB, CSI, DSI, HDMI, and MicroSD and other many interfaces.
  • CPU: Actions SOC S700,ARM Cortex-A53 Quad-Core CPU
  • GPU:Mali450 MP4 GPU ,OpenGL ES2.0/1.1 OpenVG 1.1 EGL 1.5
  • 2GB LPDDR3
  • 8GB eMMC flash onboard
  • BPI-S64 core board.
  • BPI-S64 core Kit with expansion development board
  • BPI-S64 core board spec
HardWare Specification of Banana pi BPI-S64 core
CPU Actions SOC S700,ARM Cortex-A53 Quad-Core CPU,Mali450 MP4 GPU
Memory 2GB LPDDR3
Storage 8GB eMMC
interface SODIMM-DDR3,204 PIN , all S700 GPIO support
size 67.5 x 30 mm
  • BPI-S64 core development kit spec
HardWare Specification of Banana pi BPI-S64 core kit
GPU Mali450 MP4 GPU ,OpenGL ES2.0/1.1 OpenVG 1.1 EGL 1.5
Memory 2GB LPDDR3
Storage 8GB eMMC
Power 12V @ 2A via DC power
Low-level peripherals 26 Pins Header, 28×GPIO, some of which can be used for specific functions including UART, I2C, SPI, PWM, I2S.
Onboard Network 1 x 10/100/1000Mbps Ethernet
Wifi/Bluetooth AP6212 WiFi and BT 4.0
On board Storage MicroSD \(TF\) card; 8G eMMC;SIM card slot
Display HDMI \(Type A\) output with HDCP 1.4, resolutions up 1920x1200; MIPI DP ;LVDS
Video decoder/encode support Real-time vide decode of most popular vide formats ,such as MPEG-4,H.264,H.265. support video encoder for baseline H.264
Audio support two audio device HDMI and headphone, also support Audio In/Out with PIN define. support 1 MIC in
HDMI Out/In 1* HDMI 1.4
Audio outputs/Inputs HDMI, I2S audio,Audio micro out
4G USB standard 4G LTE interface
USB 3.0 1x USB 3.0 host
USB 2.0 1x USB 2.0 OTG, 1 x USB port
Display 1* Mini DP ,1* LVDS lcd,
Camera 1 x DVP camera interface ,1 x MIPI interface
RTC battery RTC battery power interface
battery 3.7V battery interface.
Buttons Reset button, Power button, ADC button
Leds Red, Green, Blue
Other IR reciever
Sizes
Power DC 5V/2A
Weight 150g
Actions S700 datasheet : https://drive.google.com/file/d/1x1V_RP4tQzn9-BkS2L90Xgyqqz3MpLWV/view?usp=sharing
