Getting Started with M1P
Revision as of 22:31, 28 May 2018 by Sinovoip (talk | contribs) (A20 CAN Bus)
BPI-M1P
Overview: BPI-M1P ubuntu linux
  The Banana Pi M1+ features onboard WiFi g/b/n. The board supports all classic projects and even more because of the onboard WIFi chip. Like its sibling, it can run operating systems including Android, Lubuntu, Ubuntu, Debian, and Raspbian.
  The Banana Pi M1+ is our upgraded M1 board. We feel like the onboard WiFi adds a lot more features to the board and makes it more convient for users to set up their linx desktop or router projects.
  • Dual-core 1.0GHz CPU
  • 1 GB DDR3 memeory
  • Mali-400 MP2 with Open GL ES 2.0/1.1
  • WiFi onbaord
Let's get start to develop on BPI-M1P, see amazing things happen.
 * Using your USB-Serial Connect debug console on M1P
Load your first image on M1P
 * apt-get install pv
 4.After step 3, then you can insert your TF card into M1P, and press power button setup M1P
SATA
1. Mount SATA on M1P
  • "mount /dev/sdx /mnt/xxx"
OTG
1. On M1P console:
2. On PC terminal:
  • If adbd was succeed to set up, insert OTG-USB interface to M1P and PC(with Ubuntu system)
  • Execute "adb devices" to see if PC has recognised M1P OTG
  • If yes, we could execute "adb shell" to connect M1P by adb now
LCD 5" & LCD 7"
  • Find "BPI_M1P_LCD7.img.gz"
  • Then execute "bpi-bootsel /usr/lib/u-boot/bananapi/bpi-M1P/BPI_M1P_LCD7.img.gz"
 File:M1P bootsel lcd7.png
Touch screen
Use iperf3 to test gmac
1. On PC Terminal:
  • Execute "iperf3 -s"
2. On M1P console:
WiFi on M1P
  • ip link set wlan0 up
  • dhclient wlan0
Ov5640
Ov8865
  • "/test_ov8865.sh"
IR function
  • Execute "getevent"
  • Use your IR device to send information to M1P
File System
Install QT
  • sudo apt-get install build-essential
  • sudo apt-get install libgl1-mesa-dev
  • sudo apt-get install libglu1-mesa-dev
  • sudo apt-get install freeglut3-dev
  • sudo apt-get install cmake
  • sudo apt-get install qt5-default qtcreator
A20 CAN Bus
In order to port can4linux to the BananaPi, the CAN module description is needed from the A20 hardware manual. can4linux is a character-driver-based Linux driver used already on desktop PCs and embedded platforms like Freescale FlexCAN (the i.MX series of micro controllers) or Xiliny Zynq.
There is a more detailed document about CAN on the A20 at: https://dl.linux-sunxi.org/A20/CAN%20Bus1.pdf
This is a tutorial for using CAN BUS on bananapi with bananian 15-01
Thank selqcir share this example:
  • Download and install "bananian-1501.img" into 8 GB SDCard.
  • Expand the root file system using "bananian-config"
  • Install missing package:
apt-get install git
apt-get update
apt-get upgrade
reboot
  • Get last bananian available, and continu to install missing package:
git clone https://github.com/Bananian/linux-bananapi
apt-get install build-essential u-boot-tools uboot-mkimage
apt-get install libusb-1.0-0 libusb-1.0-0-dev git wget fakeroot kernel-package zlib1g-dev libncurses5-dev
apt-get install subversion
  • Build kernel:
cd linux-bananapi
make menuconfig
  • Exit without saving when menu appears
zcat /proc/config.gz > /root/linux-bananapi/.config
make uImage modules
make INSTALL_MOD_PATH=output modules_install
  • At this step, kernel should be compiled and "Module.symvers" should be available
  • Then rename modules and firmware provide by Bananian, and replace by the new one.
mv /lib/modules /lib/modules.old
mv /lib/firmware /lib/firmware.old
mv /root/linux-bananapi/output/lib/modules /lib/modules
mv /root/linux-bananapi/output/lib/firmware /lib/firmware
  • Same for uImage:
mount /dev/mmcblk0p1 /mnt
cd /mnt
mv uImage uImage.old
mv /root/linux-bananapi/arch/arm/boot/uImage /mnt
reboot
  • Create link for further build:
cd /lib/modules/3.4.104/
ln -s /root/linux-bananapi build
cd ~
  • Get Can4Linux and build it:
svn checkout https://svn.code.sf.net/p/can4linux/code/trunk can4linux-code
cd /root/can4linux-code/can4linux/
make TARGET=BANANAPI
  • Install module for each startup of the board:
insmod can4linux.ko
cp can4linux.ko /lib/modules/3.4.104/kernel/net/can/
depmod -A -v
modprobe -v can4linux
echo "" >> /etc/modules ; echo "can4linux" >> /etc/modules
reboot
  • Build CAN example
apt-get install swig
apt-get install python-dev
cd can4linux-code/can4linux-examples/
  • Update CAN speed and device in file "pyCan-example.py"
# setting the device number
device = 0
defaultBaudrate = '250'
  • Connect CAN transceiver and CAN bus, and check with for example:
  python pyCan-example.py
That's all
With this method, kernel version is "Linux bananapi 3.4.104" instead of "Linux bananapi 3.4.104+", because i was unable to find same sources than Bananian 15-01 , but CAN bus work !
