Getting Started with R2
Revision as of 01:44, 6 May 2018 by 120.234.130.204 (talk) (Ubuntu)
  • Mali 450 MP4 GPU
  • 2G DDR3 SDRAM
  • Mini PCIE interface
  • SATA interface
 1.Prepare 16G/above TF card, USB-Serial interface, Ubuntu System
 2.Using your USB-Serial Connect debug console on R2
Load your first image on R2
 * apt-get install pv
Build your own image on R2
 1. Clone Bsp project from Github,
 git clone
 3. After finish built, you will find xxSD.img and xxEMMC.img in SD directory.
OpenWrt
Develop 4G module with R2
Wifi and Ap mode on R2
Reference Link
