Banana Pi BPI-W2
- Mali T820 MP3 GPU
- 2G DDR4 SDRAM
- 8G eMMC flash
- 2xMIC int/Audio out
- 2 SATA interface
- 1xUSB 3.0 2xUSB 2.0
- HDMI in & HDMI out
- Mini DP
- TYPE C
HardWare Specification of Banana pi BPI-R2 | |||
Soc | Realtek RTD1296 quad-core ARM A53 | ||
GPU | Mali T820 MP3 GPU | ||
SDRAM | 2GB DDR4 \(shared with GPU\) | ||
Power | 12V @ 2A via DC power | ||
Low-level peripherals | 40 Pins Header, 28×GPIO, some of which can be used for specific functions including UART, I2C, SPI, PWM, I2S. | ||
Onboard Network | 2x 10/100/1000Mbps Ethernet | ||
Wifi/Bluetooth | **Option** ,not support onboard WIFI & BT | ||
RGMII | 1 RGMII interface with PIN | ||
On board Storage | MicroSD \(TF\) card; 2 native SATA 3 6Gbps ;eMMC;SIM card slot | ||
Display | HDMI \(Type A\) output with HDCP 1.4, resolutions up 1920x1200; MIPI DP | ||
Video decoder/encode | The Video DSP of RTD1296 is dedicated to manipulating,decoding and encoding of video streams in various formats, e.g. decoding 4K2K H.265,Full HD MPEG1/2/4/H.264/H.264 MVC,AVC/VC-1,VP8,AVS,AVS Plus,HD jpeg,etc.Video decoding and encoding can run simultaneously. support 3D de-intrlacing,video scaling up to 4K2K and so on. | ||
Aideo decoding | Audio decoding is carried out by an Audio DSP that is capable of decoding a set of audio formats,e.g. DTS HD,Dolby Digital Plus,TrueHD,and other popular formats.the Audio DSP also performs audio post processing | ||
Audio | support two audio device HDMI and headphone, also support Audio In/Out with PIN define. support 2 MIC in | ||
HDMI Out/In | 1\* HDMI out port and 1\* HDMI In port | ||
Audio outputs/Inputs | HDMI, I2S audio,Audio micro out, Audio out/in with PIN define | ||
M.2 KEY E:PCIE 2.0/USB 2.0 | 1 pcie 2.0 interface | ||
M.2 KEY E:PCIe 1.1 / SDIO / USB 2.0 | 1 pcie 1.1 and SDIO interface | ||
USB 2.0 | 2x USB 2.0 OTG, 1 with standard USB port , 1 define with PIN | ||
M.2 KEY B | 1 * M.2 interface USB 2.0 for 4G with Micro SIM card slot | ||
Mini DP | 1* Mini DP | ||
TYPE C | 1 type C interface | ||
RTC battery | RTC battery power interface | ||
Buttons | Reset button, Power button, U-boot button | ||
Leds | Red, Green, Blue | ||
Other | IR reciever | ||
Sizes | 148 mm × 100.5mm | ||
Weight | 100g |
Banana Pi BPI-W2 40-pin GPIO | |||
GPIO Pin Name | Default Function | Function 2:GPIO | |
CON1-P01 | VCC-3V3 | ||
CON1-P02 | 5VD | ||
CON1-P03 | I2C5\_SCL | GPIO13 | |
CON1-P04 | 5VD | ||
CON1-P05 | I2C5\_SDA | GPIO14 | |
CON1-P06 | GND | ||
CON1-P07 | PWM0\_0 | IGPIO21 | |
CON1-P08 | UR2\_TX | IGPIO3 | |
CON1-P09 | GND | ||
CON1-P10 | UR2\_RX | IGPIO2 | |
CON1-P11 | GPIO17 | GPIO17 | |
CON1-P12 | AO\_BCK | GPIO58 | |
CON1-P13 | I2C3\_SDA | GPIO25 | |
CON1-P14 | GND | ||
CON1-P15 | I2C3\_SCL | GPIO27 | |
CON1-P16 | UR2\_RTS | IGPIO5 | |
CON1-P17 | VCC-3V3 | ||
CON1-P18 | UR2\_CTS | IGPIO4 | |
CON1-P19 | G\_MOSI | GPIO7 | |
CON1-P20 | GND | ||
CON1-P21 | G\_MISO | GPIO4 | |
CON1-P22 | IR\_TX | IGPIO9 | |
CON1-P23 | G\_SCK | GPIO5 | |
CON1-P24 | G\_CS | GPIO6 | |
CON1-P25 | GND | ||
CON1-P26 | GPIO8 | GPIO8 | |
CON1-P27 | I2C4\_SDA | GPIO12 | |
CON1-P28 | I2C4\_SCL | GPIO11 | |
CON1-P29 | GPIO100 | GPIO100 | |
CON1-P30 | GND | ||
CON1-P31 | AI\_CK | GPIO21 | |
CON1-P32 | SPDIF | GPIO54 | |
CON1-P33 | AO\_CK | GPIO59 | |
CON1-P34 | GND | ||
CON1-P35 | AO\_LRCK | GPIO57 | |
CON1-P36 | AI\_BCK | GPIO22 | |
CON1-P37 | AI\_LRCK | GPIO23 | |
CON1-P38 | AI\_SDO | GPIO24 | |
CON1-P39 | GND | ||
CON1-P40 | AO\_D0 | GPIO60 |
BPI-W2 Debug UART(CON3) | |||
CON2-P1 | GND | ||
CON2-P2 | UART0-RX | ||
CON2-P3 | UART0-TX |
voltage domain is RGMII.
- BPI-W2 Realtek 1296 documents download link
- SATA-RSM-C052-X22XX spec
Android 6.0.1
- Image Link:
- Forum thread:
- Image Link:
- Forum thread:
Ubuntu 16.04
- Image Link:
- Baidu Drive:
- Google Drive:
- Forum thread:
