Getting Started with M2 Zero
BPI-M2 Zero
- Read more about : Banana Pi BPI-ZERO
- 512MB SDRAM.
- Mini HDMI.
How to create a image
OTG
1. On M2 Zero console:
2. On PC terminal:
USB Ethernet
- Use iperf3 to test network
- Execute "bluetoothctl"
- Execute these commands:
We use HDF5640 camara.
IR function
- Execute "getevent"
- Use your IR device to send information to M2 Zero
WringPi
