Getting Started with M2 Zero
Revision as of 18:36, 22 May 2018 by JackZengWiki (talk | contribs) (Introduction)
BPI-M2U
  • 512MB SDRAM.
  • Mini HDMI.
Let's get start to develop on BPI-M2P, see amazing things happen.
 * Using your USB-Serial Connect debug console on M2P
Load your first image on M2P
 * Here is the example forum thread link: http://forum.banana-pi.org/t/banana-pi-bpi-m2p-new-image-release-ubuntu-16-04-v1-1/5719
 * apt-get install pv
 4.After step 3, then you can insert your TF card into M2P, and press power button setup M2P.
Load your first image on M2P EMMC
 * Run your M2P with TF card
 * Plug your USB disk in M2P
 * After M2P recognise USB disk, execute "bpi-copy xxx-sd-emmc-xxx.img.zip / xxx-sd-emmc-xxx.img" to install image on EMMC
 * Then power off M2P, take TF card out, power on M2P with EMMC
How to build uboot & kernel
How to create a image
  • Boot your SD card with M2P, after M2P finish starting, copy your files and config your system, then poweroff M2P. [If you don't want to config your system, you can skip this step]
  • Execute "bpi-migrate -c bpi-m2p.conf -c ubuntu-mate-from-sd.conf -d /dev/sdx"
OTG
1. On M2P console:
2. On PC terminal:
  • If adbd was succeed to set up, insert OTG-USB interface to M2P and PC(with Ubuntu system)
  • Execute "adb devices" to see if PC has recognised M2P OTG
  • If yes, we could execute "adb shell" to connect M2P by adb now
  • Use iperf3 to test gmac
  • Execute "bluetoothctl"
  • Execute these commands:
WiFi on M2P
Driver code:
  • ip link set wlan0 up
  • dhclient wlan0
We use HDF5640 camara.
IR function
  • Execute "getevent"
  • Use your IR device to send information to M2P
WringPi
