Banana Pi BPI-M2+
Overview: Allwinner H3
Overview: back
Overview:3D design
Overview:Case
  • Allwinner H3 Quad-core 1.2GHz Cortex-A7 (option H2+ H5).
  • 1GB DDR3
  • 8GB eMMC onboard
  • HDMI out
  • WiFi and BlueTooth onboard
  • CSI camera interface
HardWare Specification of Banana Pi M2+(Plus)
Flash 8GB eMMC flash onboard
Network 10/100/1000 Ethernet
Audio Outputs HDMI
LED Power led & Status led
IR IR input on board
CON2-P01 VCC-3V3
CON2-P02 VCC-5V
CON2-P03 TWI0-SDA PA12-EINT12
CON2-P04 VCC-5V
CON2-P05 TWI0-SCK PA11-EINT11
CON2-P06 GND
CON2-P07 PWM1 PA6-EINT6
CON2-P09 GND
CON2-P11 UART2-RX PA1-EINT1
CON2-P13 UART2-TX PA0-EINT0
CON2-P14 GND
CON2-P15 UART2-CTS PA3-EINT3
CON2-P17 VCC-3V3
CON2-P18 PC4 PC4
CON2-P19 SPI0-MOSI PC0
CON2-P20 GND
CON2-P21 SPI0-MISO PC1
CON2-P22 UART2-RTS PA2-EINT2
CON2-P23 SPI0-CLK PC2
CON2-P24 SPI0-CS PC3
CON2-P25 GND
CON2-P26 PC7 PC7
CON2-P27 TWI1-SDA PA19-EINT19
CON2-P28 TWI1-SCK PA18-EINT18
CON2-P29 PA7-EINT7 PA7-EINT7
CON2-P30 GND
CON2-P31 PA8-EINT8 PA8-EINT8
CON2-P33 PA9-EINT9 PA9-EINT9
CON2-P34 GND
CON2-P39 GND
CN3-P01 NC
CN3-P02 GND
CN3-P03 CSI0-SDA PE13
CN3-P04 CSI0-AVDD
CN3-P05 CSI0-SCK PE12
CN3-P06 CSI0-Reset PE14
CN3-P07 CSI0-VSYNC PE3
CN3-P08 CSI0-PWDN PE15
CN3-P09 CSI0-HSYNC PE2
CN3-P10 CSI0-DVDD
CN3-P11 CSI0-DOVDD
CN3-P12 CSI0-D7 PE11
CN3-P13 CSI0-MCLK PE1
CN3-P14 CSI0-D6 PE10
CN3-P15 GND
CN3-P16 CSI0-D5 PE9
CN3-P17 CSI0-PCLK PE0
CN3-P18 CSI0-D4 PE8
CN3-P19 CSI0-D0 PE4
CN3-P20 CSI0-D3 PE7
CN3-P21 CSI0-D1 PE5
CN3-P22 CSI0-D2 PE6
CN3-P23 GND
CN3-P24 CSI0-DOVDD
Uart PIN of Banana pi BPI-M2+
CON3 P03 UART0-TXD PA4
CON3 P02 UART0-RXD PA5
CON3 P01 GND
Android 4.4
  • Image Link:
Baidu Drive:https://pan.baidu.com/s/1gfr7vJ9
Forum thread:**http://forum.banana-pi.org/t/bpi-m2-new-image-android-4-4-version-v3/2765
Rasbian Linux
Kernel 3.4
  • 2018-5-22 update : Raspbian jessie 8.0
Image Link:
baidu cloud :https://pan.baidu.com/s/16KJbtwjT_PBCZJkYV79_ag
Forum thread:
Kernel 3.4
  • 2018-5-17 update : Ubuntu 16.04 V1.1
Image Link:
Forum thread:
Image Link:
Forum thread:
Kernel 4.4
Forum thread:
http://forum.banana-pi.org/t/bpi-m2-new-image-bpi-m2-kernel-4-4-55/4577
Armbian image
Openelec Kodi
  • Openelec Kodi 16.0 (xbmc)
Raspbian
  • 2018-5-22 update : Raspbian 8.0 V1.1
Image Link:
Forum thread:
FreeBSD
Lakka TV
Dietpi
RetroPie
Others image
