Getting Started with M2P
Revision as of 17:37, 21 May 2018 by JackZengWiki (talk | contribs) (→Load your first image on M2U EMMC)
BPI-M2+ H3
- 1GB DDR3
- 8GB eMMC onboard
- WiFi and BlueTooth onboard
Let's get start to develop on BPI-M2P, see amazing things happen.
Load your first image on M2P
1.You could download latest image from our forum * Here is the example forum thread link: http://forum.banana-pi.org/t/banana-pi-bpi-m2p-new-image-release-ubuntu-16-04-v1-1/5719
2.Install bpi-tools on your Ubuntu * apt-get install pv * curl -sL https://github.com/BPI-SINOVOIP/bpi-tools/raw/master/bpi-tools | sudo -E bash
4.After step 3, then you can insert your TF card into M2P, and press power button setup M2P.
Load your first image on M2P EMMC
* Run your M2P with TF card * Copy "xxx-sd-emmc-xxx.img.zip / xxx-sd-emmc-xxx.img" to your USB disk * Plug your USB disk in M2P * After M2P recognise USB disk, execute "bpi-copy xxx-sd-emmc-xxx.img.zip / xxx-sd-emmc-xxx.img" to install image on EMMC * Then power off M2P, take TF card out, power on M2P
How to build uboot & kernel
How to create a image
- Prepare a SD card which have installed system(Ubuntu/Respbian/..)
- Use iperf3 to test gmac
- Execute "bluetoothctl"
- Execute these commands:
WiFi on M2P
Driver code:
We use HDF5640 camara.
IR function
- Execute "getevent"
WringPi
