BPI NB-IoT Linaro 96Boars
1.NB-IoT module:
- Model and Frequency band:
SIM card:
- Micro SD SIM Slot
2,MCU:
Hardware inerface
Harware spec
HardwareSpecification of BPi BC95-LINARO | |||
Soc | STM32F103RBT6 | ||
CPU | ARM 32-bit Cortex™-M3 CPU @72MHz | ||
SDRAM size | 20 KB | ||
Flash size | 128KB | ||
Power | 5V/2A via MicroUSB / 2PIN Battery Connector | ||
Low-level peripherals | 40 Pins Header \(2.0mm Pitch\), 32×GPIOs,Some of which can be used for specific functions including UART, I2C, SPI, PWM | ||
On board Network | Quectel BC95 | ||
On board SIM | MicroSD SIM SloteSIM\(option\) | ||
USB | 1 USB 2.0 host | ||
Buttons | Reset button, User button | ||
Leds | 1 Power status Led and 5 other Leds | ||
Sizes | 60mm×30mm | ||
Weight | 10g |
Dimensions
GPIO (CON1) define
40 PIN GPIO (CON1) define:
Software introduction
1 ,Lite OS brief Huawei
2,BC95 software brief:
Command format:
- Searching network steps:
- AT+NBAND?//QueryBand
- AT+CFUN?//value :1
- AT+CIMI//Query IMSI number
- AT+CSQ/Query the signal strength
- AT+NUESTATS//Query module status
- AT+CGATT?//Back + CGATT: 1 indicates that the attachment is successful, with a delay of about 30s
- AT+CEREG?//Search for network status, 1 for Internet, 2 for Network
- AT+CSCON?//Query the connection status, 1 CONNECT, 0 IDLE
- Manually configure network if fails to register network automatically:
- AT+CFUN=1 AT+CIMI//Execute CFUN = 1, wait for 4 seconds to query IMSI, if it can be found that the card has been identified;If not, please check the card is inserted and confirm whether it is a USIM card.
- AT+NBAND?//Query frequency band information.
- AT+CEREG=1//Set to automatically register network registration status, when the module registered on the network, will report URC.**AT+CGDCONT=1,“IP”,“APN”**//The APN is configured locally \(or not configured\) for local access.
- AT+COPS=1,2,"46000"**//Specify PLMN search, PLMN configuration.
- AT+CSQ//Query signal strength.
- AT+NUESTATS// Query module status
How to setup and start to use
Hardware preparation
- BPI OPEN DEBUGGER or J-Link DEBUGGER *1
- BPI BC95-Linaro development board *1
- Micro USB cable *2*
- Dupont lines\(female female\)*4
Hardware hookup
There are two ways to flash by either BPI OPEN DEBUGGER or J-Link DEBUGGER:
connect way | |||
BPI OPEN DEBUGGER | BPI NB-IoT Linaro SWD | ||
3V3 | VCC | ||
GND | GND | ||
DIO | DIO | ||
CLK | CLK |
2.J-Link DEBUGGER:
The corresponding connection between JLink and BPI BC95 are the following:
connect way | |||
J-link | BPI NB-IoT Linaro SWD | ||
3V3 \(Pin1\) | VCC | ||
GND \(Pin4.6.8.10……\) | GND | ||
SWDIO \(Pin7\) | DIO | ||
SWCLK \(Pin9\) | CLK | ||
nJTRST (Pin3)optional | RST \(optional\) |
3.Software debugging setting:
MDK5 setting:
Create a project choosing the right chip,and set the Options of Target as follows:
4.Software sample cases:
There are two samples in BPI forum, please refer to the following links:
1.https://github.com/yelvlab/BPI_NB-IoT_Linaro_96Boards/tree/master/example/Debugger_USART
2.https://github.com/yelvlab/BPI_NB-IoT_Linaro_96Boards/tree/master/example/Debugger_Virtual_USB
3.Github code :https://github.com/yelvlab/BPI_NB-IoT_Linaro_96Boards
HUAWEI LiteOS:
BPI NB-Iot Linaro 96Boards Easy Development with Arduino
- HUAWEI LiteOS:
- LiteOS_Partner Development Kits:
- BPI github :
- BPI NB-Iot Linaro 96Boards Easy Development with Arduino
- Quecte BC95 datasheet (CN version)
- STM32F103(LD) datasheet.
- Discuss on forum :
- Easy to buy sample:
