Getting Started with M2 Ultra & Berry
BPI-M2U
File:M2p respbian.jpg
Overview: BPI-M2U respbian linux
- 2GB DDR3 SDRAM
- 8 GB eMMC storage
- SATA Interface
BPI-M2 Berry
Banana Pi BPI-M2 Berry is a quad-core mini single board computer built with Allwinner V40 SoC. It features 1GB of RAM . It also has onboard WiFi and BT. On the ports side, the BPI-M2 Ultra has 4 USB A 2.0 ports, 1 USB OTG port, 1 HDMI port, 1 audio jack, a DC power port, and last but not least, a SATA port..
- Read more about : Banana Pi BPI-M2 Berry
- Quad Core ARM Cortex A7 CPU V40.
- 1GB DDR3 SDRAM.
- SATA Interface
Load your first image on M2U
1.You could download latest image from our forum * Here is the example forum thread link:
2.Install bpi-tools on your system * apt-get install pv * curl -sL https://github.com/BPI-SINOVOIP/bpi-tools/raw/master/bpi-tools | sudo -E bash
SATA
1. Mount SATA on M2U
- "fdisk /dev/sdx" to create new partition , after created input "wq" to save and quit.
- "mount /dev/sdx /mnt/xxx"
OTG
1. On M2U console:
2. On PC terminal:
LCD 5" & LCD 7"
- Find "BPI_M2U_LCD7.img.gz"
Touch screen
Use iperf3 to test gmac
1. On PC Terminal:
- Execute "iperf3 -s"
2. On M2U console:
- Execute "bluetoothctl"
- Execute these commands:
WiFi on M2U
We use HDF5640 camara.
IR function
- Execute "getevent"
WringPi
- Execute "/usr/local/bin/bpi_test_lcd1602"
- Execute "/usr/local/bin/bpi_test_52pi"
- Execute "/usr/local/bin/bpi_test_gpio40"
