BPI-Bit
BPI:bit hardware
BPI:bit hardware description
BPI:bit interface
BPI:bit edge interface
BPI:bit PIN define
P3 | ADC2_CH4 | GPIO13 | |||
P4 | ADC2_CH3 | GPIO16 | |||
P5 | ADC1_CH7 | GPIO35 | |||
P6 | ADC2_CH5 | GPIO12 | |||
P7 | ADC2_CH6 | GPIO14 | |||
P1 | ADC1_CH4 | GPIO32 | |||
P8 | GPIO16 | ||||
P9 | GPIO17 | ||||
P11 | ADC2_CH7 | GPIO27 | |||
P12 | ADC2_CH2 | GPIO02 | |||
P2 | ADC1_CH5 | GPIO33 | |||
P13 | GPIO18 | SPI_SS | |||
P14 | GPIO19 | SPI_SCK | |||
P15 | GPIO23 | SPI_MISO | |||
P16 | GPIO05 | SPI_MOSI | |||
3V3 | POWER:3V3 | ||||
P19 | GPIO22 | I2C_SCL | |||
P20 | GPIO21 | I2C_SDA | |||
GND | GROUND | ||||
GND | GROUND | ||||
GND | GROUND |
5*5 LED list
BPI:bit have 25 LEDs on board ,you can control it with 1 GPIO . easy to use it.
20 | 15 | 10 | 5 | 0 |
21 | 16 | 11 | 6 | 1 |
22 | 17 | 12 | 7 | 2 |
23 | 18 | 13 | 8 | 3 |
24 | 19 | 14 | 9 | 4 |
MPU9250
A powerful 9 axis sensor, MPU9250, is placed on the BPI:bit board.
BPI:bit VS Micro:bit
BPI:bit VS Micro:bit | |||
Module | BPI:bit | Micro:bit | |
CPU | Xtensa 32bit LX6 single/dual-core | 32bit Arm cortex M0 | |
RAM | 520KB | ||
ROM | 448KB | ||
WIFI | 802.11 b/g/n/e/i | N/A | |
Bluetooth | BT4.2 BR/EDR and BLE | BLE | |
photosensitive sensor | 2 light sensor | ||
temperature sensor | 1 temperature sensor | ||
other senesor | MPU-9250 9-axis MotionTracking : 3-axis gyroscope, 3-axis accelerometer, 3-axis magnetometer | ||
Buzzer | 1x Buzzero | ||
5*5 LEDS | 25 intelligent control LED light ,Cascading port transmission signal by single line. completed 16777216 color full color display | 25 single color LED stands for Light Emitting Diode. The micro:bit has 25 individually-programmable LEDs | |
25 GPIO | edge interface (compatibility micro:bit) | edge interface | |
Button | 2 programmable buttons | 2 programmable buttons | |
micro USB | 1x micro USB(Uart) | 1 x micro USB | |
Software | Webduino,Arduino | Micro:bit function | |
Size | 5*5 cm | 5*4 cm |
BPI-bit software
BPI:bit for webduino
- Quick start Webduino Blockly and simulator
Burning method:
Select ESP32 DownloadTool:
File and burn position corresponding | |||
set | file name | Position | |
1 | bootloader_dio_40m.bin | 0x1000 | |
2 | partitions.bin | 0x8000 | |
3 | boot_app0.bin | 0xe000 | |
4 | bit_default.bin | 0x10000 |
- SpiFlashConfig:
SpiFlashConfig | |||
1 | SPI SPEED | 40NHz | |
2 | SPI MODE | DIO | |
3 | FLASH SIZE | 32Mbit | |
4 | COM | COMx(Fill in the port number assigned by the computer) | |
5 | BAUD | 1152000 |
During the burning process:
Finished:
Burn time is about 20s
BPI: bit Online tutorials
BPI:bit for arduino
Arduino
- BPI:bit for webduino source code on github: https://github.com/webduinoio
- BPI:bit for arduino Source code on Github: https://github.com/yelvlab/BPI-BIT
documents
- Taiwan server : http://webuino.io
- Overworld server: http://webduino.io
- china mainland : http://www.webduino.com.cn
