Banana Pi BPI-M2 Berry
Revision as of 08:08, 5 May 2018 by Sinovoip (talk | contribs) (GPIO PIN define)
Banana Pi BPI-M2 Berry is a quad-core mini single board computer built with Allwinner V40 SoC. It features 1GB of RAM . It also has onboard WiFi and BT. On the ports side, the BPI-M2 Ultra has 4 USB A 2.0 ports, 1 USB OTG port, 1 HDMI port, 1 audio jack, a DC power port, and last but not least, a SATA port..
  • 1GB DDR3 SDRAM.
  • SATA Interface.
  • 4*USB 2.0
HardWare Specification of Banana pi BPI-M2 Berry
Soc Allwinner R40/V40
SDRAM 1GB DDR3 with 733MHz\(shared with GPU\)
SATA suppoort SATA interface
Bluetooth BT4.0
On board Storage MicroSD \(TF\) card,No eMMC onboard
USB 4 USB 2.0 host, 1 USB 2.0 OTG
IR No onboard IR receiver
battery No 3.7V lithium battery power support
Weight 40g
CON1-P02 DCIN
CON1-P03 TWI2-SDA PB21 PWM5
CON1-P04 DCIN
CON1-P05 TWI2-SCK PB20 PWM4
CON1-P07 PB3 PB3 PWM1
CON1-P11 UART7-TX PI20 PWM2
CON1-P13 UART7-RX PI21 PWM3
CON1-P15 PH25 PH25 CSI1-FIELD
CON1-P18 PH26 PH26 CSI1-HSYNC
CON1-P19 SPI0\_MOSI PC0
CON1-P21 SPI0\_MISO PC1
CON1-P22 PH27 PH27 CSI1-VSYNC
CON1-P23 SPI0\_CLK PC2
CON1-P24 SPI0\_CS PC23
CON1-P26 PH24 PH24 CSI1-PCLK
CON1-P27 TWI3-SDA PI1
CON1-P28 TWI3-SCK PI0
CON1-P29 PH0 PH0 CSI1-D0
CON1-P31 PH1 PH1 CSI1-D1
CON1-P32 PD20 PD20 CSI1-MCLK
CON1-P33 PH2 PH2 CSI1-D2
CON1-P35 PH3 PH3 CSI1-D3
CON1-P36 UART5-RX PH7 CSI1-D7
CON1-P37 UART4-TX PH4 CSI1-D4
CON1-P38 UART5-TX PH6 CSI1-D6
CON1-P40 UART4-RX PH5 CSI1-D5
  • CSI Camera Connector specification:**
| CSI Pin Name | Default Function | Function2:GPIO | | :--- | :--- | :--- | | CN5-P01 | NC | | | CN5-P02 | GND | | | CN5-P03 | CSI0-SDA | PI3 | | | CN5-P04 | CSI0-AVDD | | CN5-P05 | CSI0-SCK | PI2 | | CN5-P06 | CSI0-Reset | PI7 | | CN5-P07 | CSI0-VSYNC | PE3 | | CN5-P08 | CSI0-PWDN | PI6 | | CN5-P09 | CSI0-HSYNC | PE2 | | | CN5-P10 | CSI0-DVDD | | | CN5-P11 | CSI0-DOVDD | | CN5-P12 | CSI0-D7 | PE11 | | CN5-P13 | CSI0-MCLK | PE1 | | CN5-P14 | CSI0-D6 | PE10 | | | CN5-P15 | GND | | CN5-P16 | CSI0-D5 | PE9 | | CN5-P17 | CSI0-PCLK | PE0 | | CN5-P18 | CSI0-D4 | PE8 | | CN5-P19 | CSI0-D0 | PE4 | | CN5-P20 | CSI0-D3 | PE7 | | CN5-P21 | CSI0-D1 | PE5 | | CN5-P22 | CSI0-D2 | PE6 | | CN5-P23 | GND | | | | CN5-P24 | CSI0-AFVCC |
    • Display specification**
| | DSI Pin Name | Default Function | Function2:GPIO | | :--- | :--- | :--- | :--- | | | | CN6-P01 | VCC-3V3 | | | | CN6-P02 | IPSOUT | | | | CN6-P03 | VCC-3V3 | | | CN6-P04 | IPSOUT | | | | | CN6-P05 | GND | | | | CN6-P06 | IPSOUT | | | | CN6-P07 | GND | | | | CN6-P08 | IPSOUT | | | | CN6-P09 | NC | | | | CN6-P10 | GND | | | | CN6-P11 | NC | | | | CN6-P12 | DSI-D0N | | | | CN6-P13 | NC | | | | CN6-P14 | DSI-D0P | | | | CN6-P15 | NC | | | | CN6-P16 | GND | | | CN6-P17 | TWI0-SDA | PB19 | | | | CN6-P18 | DSI-D1N | | | CN6-P19 | TWI0-SCK | PB18 | | | | CN6-P20 | DSI-D1P | | | CN6-P21 | CTP-INT | PI10 | | | CN6-P22 | GND | | | | CN6-P23 | CTP-RST | PI11 | | | CN6-P24 | DSI-CKN | | | | | CN6-P25 | GND | | | | CN6-P26 | DSI-CKP | | | CN6-P27 | LCD-BL-EN | PH16 | | | | CN6-P28 | GND | | | CN6-P29 | LCD-RST | PH17 | | | | CN6-P30 | DSI-D2N | | | CN6-P31 | LCD-PWR-EN | PH18 | | | | CN6-P32 | DSI-D2P | | | | CN6-P33 | GND | | | | CN6-P34 | GND | | | CN6-P35 | LCD-PWM | PB2 | | | | CN6-P36 | DSI-D3N | | | | CN6-P37 | GND | | | | CN6-P38 | DSI-D3P | | | | CN6-P39 | NC | | CN6-P40 | GND | | |
    • UART specification:**
| | CON2 Pin Name | Default Function | GPIO | | :--- | :--- | :--- | :--- | | | CON2 P03 | UART0-TXD | | | | CON2 P02 | UART0-RXD | | | CON2 P01 | GND | | |
Opnewrt
Release
