BPI-Bit
BPI:bit hardware
BPI:bit hardware description
BPI:bit interface
BPI:bit edge interface
BPI:bit PIN define
| P8 | GPIO16 | ||||
| P9 | GPIO17 | ||||
| P13 | GPIO18 | SPI_SS | |||
| 3V3 | POWER:3V3 | ||||
| GND | GROUND | ||||
| GND | GROUND | ||||
| GND | GROUND | ||||
5*5 LED list
| 20 | 15 | 10 | 5 | 0 |
| 21 | 16 | 11 | 6 | 1 |
| 22 | 17 | 12 | 7 | 2 |
| 23 | 18 | 13 | 8 | 3 |
| 24 | 19 | 14 | 9 | 4 |
MPU9250
A powerful 9 axis sensor, MPU9250, is placed on the BPI:bit board.
BPI:bit VS Micro:bit
| BPI:bit VS Micro:bit | |||
| BPI:bit | Micro:bit | ||
| CPU | Xtensa 32bit LX6 single/dual-core | 32bit Arm cortex M0 | |
| RAM | 520KB | ||
| ROM | 448KB | ||
| WIFI | 802.11 b/g/n/e/i | N/A | |
| Bluetooth | BT4.2 BR/EDR and BLE | BLE | |
| 5*5 LEDS | 25 intelligent control LED light ,Cascading port transmission signal by single line. completed 16777216 color full color display | 25 single color LED stands for Light Emitting Diode. The micro:bit has 25 individually-programmable LEDs | |
| Button | 2 programmable buttons | 2 programmable buttons | |
| Size | 5*5 cm | 5*4 cm | |
BPI-bit software
BPI:bit for webduino
BPI: bit Webduino Firmware Burning
Burning method:
Select ESP32 DownloadTool:
- SpiFlashConfig:
| SpiFlashConfig | |||
| 1 | SPI SPEED | 40NHz | |
| 2 | SPI MODE | DIO | |
| 3 | FLASH SIZE | 32Mbit | |
| 4 | COM | COMx(Fill in the port number assigned by the computer) | |
| 5 | BAUD | 1152000 | |
During the burning process:
Finished:
Burn time is about 20s
BPI:bit for arduino
Arduino
- BPI:bit for webduino source code on github: https://github.com/webduinoio
- BPI:bit for arduino Source code on Github: https://github.com/yelvlab/BPI-BIT
documents
- Taiwan server : http://webuino.io
- Overworld server: http://webduino.io
- china mainland : http://www.webduino.com.cn
