Banana Pi BPI-M2 Berry
Revision as of 07:45, 5 May 2018 by Sinovoip (talk | contribs) (Hardware spec)
Banana Pi BPI-M2 Berry is a quad-core mini single board computer built with Allwinner V40 SoC. It features 1GB of RAM . It also has onboard WiFi and BT. On the ports side, the BPI-M2 Ultra has 4 USB A 2.0 ports, 1 USB OTG port, 1 HDMI port, 1 audio jack, a DC power port, and last but not least, a SATA port..
  • 1GB DDR3 SDRAM.
  • SATA Interface.
  • 4*USB 2.0
HardWare Specification of Banana pi BPI-M2 Berry
Soc
CPU
GPU
SDRAM
SATA
GPIO
On board Network
Wifi Module
MicroSD \(TF\) card,** **_**No eMMC onboard**_ |
4-lane MIPI DSI display,or RGB panel or LVDS panel,TV-out on HDMI V1.4 |
Multi-format FHD video decoding, including Mpeg1/2, Mpeg4, H.263, H.264, etc H.264 decode up to 1080P60,support video encodeing:High-deinition\(HD\)H.264 video encoder is up to 1080P@45fps |
HDMI, analog audio \(via 3.5 mm TRRS jack\), I2S audio \(also potentially for audio input\) |
A CSI input connector Camera:Supports 8-bit YUV422 CMOS sensor interface,Supports CCIR656 protocol for NTSC and PAL,Supports 5M pixel camera sensor ,Supports video capture solution up to 1080p@30fps |
Audio input
USB
Buttons
Leds
IR
DC Power
battery
Sizes
Weight
Opnewrt
Release
