Getting Started with M2P
Overview: BPI-M2+ Ubuntu linux
Overview:no eMMC onboard
Read more: Banana Pi BPI-M2+
BPI-M2+ H3
  • Quad-core 1.2GHz Cortex-A7 H3
  • 1GB DDR3
  • 8GB eMMC onboard
  • WiFi and BlueTooth onboard
Let's get start to develop on BPI-M2P, see amazing things happen.
Load your first image on M2P
 * Here is the example forum thread link: http://forum.banana-pi.org/t/banana-pi-bpi-m2p-new-image-release-ubuntu-16-04-v1-1/5719
 * apt-get install pv
 4.After step 3, then you can insert your TF card into M2P, and press power button setup M2P.
  • Use iperf3 to test gmac
  • Execute "bluetoothctl"
  • Execute these commands:
WiFi on M2P
  • ip link set wlan0 up
  • dhclient wlan0
We use HDF5640 camara.
  • test_ov5640_image_mode.sh
  • cameratest.sh
IR function
  • Execute getevent
  • Use your IR device to send information to M2P
WringPi
  • Execute bpi_test_lcd1602
  • Execute bpi_test_52pi
  • Execute bpi_test_gpio40
Reference Link
