Banana Pi BPI-M2 Berry
BPI-M2 Berry is the open source hardware platform,BPI-M2 Berry is a quad-core cortex -A7 CPU ,use Allwinner R40/V40 design, it support WIFI+BT on board.and support SATA interface on board.
Banana PI BPI-M2 Berry with Gigabit Ethernet port, It can run Android smoothly. The size of Banana PI BPI-M2 Berry same as Banana Pi BPI-M64, support 1080P video, the 40 pin GPIO header is pin-compatible with Raspberry Pi.
The new BPI-M2 Berry is a tiny little computer with great big ambitions. The expandable single-board device runs either Linux or Android and features impressive specs that outshine comparable products by a substantial margin. Highlights include a quad-core ARMv7 processor, a Mali 400 MP2 GPU, and support for 1080P ultra high-definition video.
