Camera
Revision as of 00:25, 17 May 2018 by Sinovoip (talk | contribs) (BPI-M2+ support OV5640 camera module)
Hardware Specification
The camera V3 module is specifically designed for BPi-M3.It include two CMOS sensor module, one is OV5640(5M Pixel),and the other is OV8865(8M Pixel),so you can choose one or two campera for this board.
camera can support 2 scene. one is OV5640 and one is OV8865
cable line
Schematic diagram
How to use
Connect the camera module and BPi-M3 with a 40PIN FFC cable, like the pictures below :
note: for BPI-M2+ , camera is not same as BPI-M2,BPI-M1.... , it support OV5640 module, not need extend board. you just can direct use OV5640 modue on CSI interface.
if you have BPI-M1/M1+/M2 camera module ,you can remove camera module from extend bard ,and can use on BPI-M2+.
connect way:
BPI camera SCH download: https://drive.google.com/file/d/0B4PAo2nW2KfnOEFTMjZ2aEVGUVU/view?usp=sharing
OV5640 datasheet download: https://drive.google.com/file/d/0B4PAo2nW2KfnbE03bldrdXdSQ1E/view?usp=sharing
OV8865 datasheet download: https://drive.google.com/file/d/0B4PAo2nW2KfnUy1yOTB2YllBSGM/view?usp=sharing
