BPI Uno Compatible Module
Produce Overview
The module makes Banana Pi compatible with Arduino Uno and many Arduino Shields. There is an ATmega328 chip on the board so the module can compatible Arduino Uno code and peripheral. This board is a combination of high operation performance of the banana pie and Arduino flexible control performance, the combination of peripheral greatly expand the banana pie access ability and the abundance of accessories.
- Produce Features:**
1. ATmega328 chip on module 2. Compatible with Arduino Uno 3. Switch 5V or 3.3V GPIO 4. Compatible with Processing code 5. Expand SPI of Banana Pi
- Port:**
1. Banana Pi connection 2. Banana Pi cascade port 3. Arduino Uno GPIO 4. Electric level switch jumper 5. SPI 6. ICSP port
- Product Specification:**
![](uno1.png)
- Product Parameters:**
1. Working voltage: 3.3V-4.5V 2. GPIO voltage: 3.3V or 5.5 3. 8 channel 10bit high resolution ADC 4. Power-down Mode: 0.1µA 5. 32K ROM 6. 2K RAM 7. −40°C to +85°C operation
- Typical Application:**
1. Automatic control 2. Arduino learning 3. Sensor control 4. 3D printer controller 5. Laser cutter controller 6. Robot controller 7. Smart home
- How to use on BPI-M1:**
Just insert the module to Banana Pi, like the below picture:
![](bpi+uno.jpg)
- More information:**
pin define:
![](uno2.png)
Schematic diagram:
![](uno3.png)
- More information please check:**
http://www.atmel.com/zh/cn/devices/atmega328.aspx
- Testbench:**
1. When power up the module , The “L” LED is blinking
