Banana Pi BPI-R3
Banana Pi BPI-R3 Router board with MediaTek MT7986(Filogic 830) Quad core ARM A53 + MT7531A chip design ,2G DDR RAM ,8G eMMC flash onboard. It is a very high performance open source router development board,support Wi-Fi 6 2.4G wifi use MT7975N and 5G wifi use MT7975P, support 2 SFP 2.5GbE port, and 5 GbE network port
Introduction Video
Application direction
- Maker DIY
- Internet service Router
- Wireless Router
- Wireless Repeater
- Home security Gateway
- Home Automation
- Nas device
- Network and communication applications
- MediaTek MT7986(Filogic 830) Quad core ARM Cortex A53+MT7531 chip design
- Wifi 6 4x4 2.4G Wifi(MT7975N) +4x4 5G Wifi(MT7975P)
- 2G DDR RAM
- 8G eMMC flash
- 128MB SPI Nand
- 2x SFP 2.5GbE
- 5x GbE network port
- Mini PCIe via USB
- M.2 KEY-M PCIe interface
- Mciro SD card interface
- 26 PIN GPIO
- POE function customizable (present version not support POE function)
Jumper setting
| CPU | MediaTek MT7986(Filogic 830) Quad core ARM Cortex A53+MT7531 chip design | ||
| SDRAM | 2 GB DDR4 | ||
| On board Network | 5 Port 10/100/1000Mbps Ethernet | ||
| SFP | 2 SFP 2.5GbE | ||
| Wifi | Wifi 6 4x4 2.4G Wifi(MT7975N) +4x4 5G Wifi(MT7975P) | ||
| M.2 interface | M.2 KEY-M PCIe inerface | ||
| USB | 1 USB 3.0 host ,2 USB interface with slot. | ||
| DC Power | 12V/2A with DC in | ||
| Weight | 200g | ||
- Official OpenWrt 21.02 for BPI-R3 repo:
- Frank’s U-Boot repo:
- Unofficial wiki (English):https://wiki.fw-web.de/doku.php?id=en:bpi-r3:start
- BPI-R3 DXF file:
- Baidu Cloud:https://pan.baidu.com/s/10L6rXjdDa1Sz0cQVDYnp8Q?pwd=8888 (pincode:8888)
- Google Drive: https://drive.google.com/file/d/1BE09wS1ca5xUdmd3DN2qyg5RYMTIC2l3/view?usp=sharing
- BPI-R3 schematic diagram
- Baidu Cloud: https://pan.baidu.com/s/1-GJNHAqNy7-JFTx22uoSfQ?pwd=8888 (pincode:8888)
- Google Drive: https://drive.google.com/file/d/1ED2z_e01Y0e6LDzMC_vLhCsTHEZTGwcg/view?usp=sharing
- Banana Pi BPI-R3 Review: Details, Pricing, & Features : https://androidpimp.com/embedded/banana-pi-bpi-r3-router-board/?fbclid=IwAR1G4cEco5iULwKG-C-n8MIiWOWZMhPborqmCzS2d3KIHx-eNQS-54lZnps
- Update OpenWrt to 22.03.3 SNAPSHOT:https://forum.banana-pi.org/t/bananapi-bpi-r3-update-openwrt-to-22-03-3-snapshot/14984
- 3D printed cases:https://forum.banana-pi.org/t/banana-bpi-r3-3d-printed-case/14246/43
- Cooling solutions topic: https://forum.banana-pi.org/t/bpi-r3-running-hot/14750
- Bananapi R3 review with WiFi / CPU benchmarks and power consumption numbers: https://wiki.junicast.de/en/junicast/review/bananapi-BPI-R3
- [Tutorial] Reworking BPI-R3 nand Flash:https://forum.banana-pi.org/t/tutorial-reworking-bpi-r3-nand-flash/15492
- BananaPi BPI-R3, now with ROOTer support!:https://wirelessjoint.com/viewtopic.php?t=3852
- OpenWRT official for Sinovoip BananaPi BPi R3: https://openwrt.org/toh/sinovoip/bananapi_bpi-r3
- Setting up the Banana-R3 with OpenWRT:https://uglyscale.press/2023/09/13/setup-the-banana-r3-with-openwrt/
Release image
- Latest official OpenWRT snapshot image:
- 2022-07-20 udptae BPI-R3 OpenWRT 21.02 linux kernel 5.4, wifi 6 2.4G and 5G mac80211 opensource wifi driver working fine support nand flash ,SD card ,eMMC flash boot. for BPI-R3 production version hardware
- Google Drive:https://drive.google.com/file/d/13nQMfM0_XTyWcILhNxv_9E4TIvb65RI0/view?usp=share_link
- Baidu Cloud: https://pan.baidu.com/s/1-5tqHEacMw1wlTSEK1ey9A?pwd=8888 (pincode: 8888)
Frank’s image
- Frank’s Debian Bullseye image:
- Frank’s Ubuntu 22.04 image:
Arch linux
Failed to save the configuration
- Enter "mtd erase /dev/mtd10"
Accessories
4G
- BPI-R3 can use Quectel EC25E minipcie-slot
SFP
Notice:
The SFP serdes of R3 are fixed 2.5Gbase-X, so only SFP that support this protocol can be used.
And there is no debugging insertion detection function, so there will be no prompt when inserting any SFP module.
The SFPs we have tested that work are as follows:
1. 2.5G Copper: SFP-2.5G-T-R-RM
2. 2.5G Optical Fiber: SFP-2.5G-BX0-U/SFP-2.5G-BX0-D
3. TP-LINK 2.5G Copper: TL-SM410U
4. TP-LINK 2.5G Optical Fiber: TL-SM411LSA-500m/TL-SM411LSA-500m
WIFI6e
- ASIA.RF AW7916-NPD:
- Module:WiFi6E 3000 802.11ax G-band 2T2R and A-band 3T3R 2ss Dual Bands Dual Concurrents mPCIe Card AW7916-NPD(With BPI-M.2 to mPCIe Adapter)
- WiFi6E Module: https://asiarf.com/product/wi-fi-6e-mini-pcie-module-mt7916-aw7916-npd/
- BPI-M.2 to mPCIe Adapter:
- Error creating thumbnail: Unable to save thumbnail to destination
- Test Items:
- As Client:
PoE
- SINOVOIP Aliexpress Shop: https://www.aliexpress.us/item/3256804530142161.html?
- Bipai Aliexpress Shop: https://www.aliexpress.us/item/3256804530395673.html?
- Taobao Shop: https://shop108780008.taobao.com/category-1696287007.htm?
