Getting Started with M2S
Revision as of 00:10, 5 July 2024 by Dangku (talk | contribs) (Luma.Examples)
BPI-M2S with Wifi&BT module
4. Only A311D variant board have camera, mipi panel and npu support.
2. Press and hold USB button on the board, plugin type-c usb cable to PC or press the RST button if power adapter already connected, about two seconds later, release the button, the board will be identified correctly.
Android DTB overlay
Bananapi M2S DTBO idx value table, default idx value is 0 in release image.
2 i2c1 enable i2c 1
3 i2c2 enable i2c 2
4 sdio enable sdio
5 uart1 enable 2 pins uart 1
7 uart2 enable 2 pins uart 2
How to apply a new dtbo
1. ADB command via sysfs
 restarting adbd as root
 remount succeeded
 bananapi_m2s:/ # reboot
 console:/ $
 console:/ $ su
 console:/ #
 console:/ #
 console:/ # reboot
3. Settings App(To-Do)
       Amlogic multi-dtb tool
       Single dtb detected
 find 2 dtbos
 dtbos to be applied: 1
 Apply dtbo 1
Install OpenGapps
2. Download device_id.apk.
udisk:
 --wipe_cache
sdcard:
 --wipe_cache
watch this video on bilibili
Switch Mipi Panel
Panel Rotation
   index 1f51703..d592a44 100644
    else
        ro.sf.lcd_density=213 \
    endif
   index 4a698b0..3d41b63 100755
   @@ -876,8 +876,8 @@
                   reg = <0x5d>;
4. Extract this tool
 $ ls -l logo/
5. Copy the boot-logo.bmp.gz
 $ adb root
 $ adb remount
 $ adb reboot fastboot
 $ fastboot device
 1234567890      fastboot
 $ fastboot reboot
3. Make sure bootable EMMC is formatted if you want bootup from SDcard, more info refer to Erase EMMC for SDcard Bootup
5. Install bpi-tools on your Linux PC(if flash image with other tools, ignore this step). If you can't access this URL or any other install problem, please go to bpi-tools source repo, download and install this tools manually.
 $ apt-get install pv
6. Download Linux latest Linux Image, and confirm that the md5 checksum is correct.
7. Default login: pi/bananapi or root/bananapi
8. The wiki guide is only for bananapi 4.9 bsp ubuntu/debian images.
Install Image to SDcard
2. Install Image with Balena Cli on Windows, Linux and MacOS.
 $ sudo balena local flash path/to/xxx-bpi-m2s-xxx.img.zip
 $ sudo balena local flash path/to/xxx-bpi-m2s-xxx.img.zip --drive /dev/disk2
 $ sudo balena local flash path/to/xxx-bpi-m2s-xxx.img.zip --drive /dev/disk2 --yes
3. Install Image with dd command on Linux, umount SDcard device /dev/sdX partition if mounted automatically. Actually bpi-copy is the same as this dd command.
 $ sudo unzip -p xxx-bpi-m2s-xxx.img.zip | pv | dd of=/dev/sdX bs=10M status=noxfer
4. Install the linux image in udisk with bpi-tools on Linux, plug SDcard to Linux PC and run
Install Image to EMMC
 $ sudo unzip -p xxx-bpi-m2s-xxx.img.zip | pv | dd of=/dev/mmcblk0 bs=10M status=noxfer
4. Install with bpi-tools command
Build Linux Source Code
2. Build the bsp source code
 i2c1.dtbo           pwm_ef.dtbo           waveshare_tft24_lcd.dtbo
 i2c2.dtbo           pwm_ef-f.dtbo         waveshare_tft35c_lcd.dtbo
 # Device Tree Overlays
 overlays="i2c2 spi0 uart1"
Enable Camera
The linux release image is camera disabled default, according to the following configuration, it can be enabled by yourself.
 overlays="os08a10"
 iv009_isp_iq
 iv009_isp_lens
 iv009_isp_sensor
 iv009_isp
 #choose isp register sequence
Switch Mipi Panel
 # Mipi panel type
 #    Symbol    | Resolution
 panel_type=lcd_0
Panel Rotation
 Section "Device"
     # Rotate off
 #   Option "Rotate" "off"
     Option "Rotate" "CW"
 #   Option "Rotate" "UD"
 #   Option "Rotate" "CCW"
 EndSection
 Section "InputClass"
     MatchIsTouchscreen "on"
     MatchProduct "goodix-ts"
     MatchDriver "libinput"
 EndSection
1. Sysfs dynamically change.
2. Boot Configuration change.
 # Framebuffer Rotate
 # 0 - origin 0 degree
 # 1 - 90 degree
 # 2 - 180 degree
 # 3 - 270 degree
 fb_rotate=0
Note: This WiringPi only support set 40pin gpio to output, input, pwm or software pwm, for io functions as i2c, spi, ..., you must enable dtb overlay in boot.ini
 $ sudo apt-get update
 $ git clone https://github.com/Dangku/WiringPi
 $ cd WiringPi
 $ chmod a+x build
 $ sudo ./build
3. BPI GPIO Extend board and examples in WiringPi/examples
oled, BPI LCD 1602 display module example.
52pi, BPI OLED Display Module example.
matrixled, BPI RGB LED Matrix Expansion Module example.
berryclip, BPI BerryClip Module
 $ git clone https://github.com/Dangku/RPi.GPIO.git
 $ cd RPi.GPIO
Create and install wheel package
Install from git source directly without development
 $ sudo pip3 install git+https://github.com/Dangku/RPi.GPIO.git
If the package is already installed, it should be uninstalled before installing the new one, or installing the new one with --force-reinstall option.
WiringPi2-Python
 $ git clone --recursive  https://github.com/Dangku/WiringPi-Python.git
 $ cd WiringPi-Python
Luma.Examples
1. build and install RPi.GPIO
build bananapi m2s RPi.GPIO with python3 instead of python because luma uses python3.
 $ cd RPi.GPIO
you can change the bcmledpin variable in test/led.py to your hardware backlight gpio and run it to check RPi.GPIO works well.
 $ sudo python3 test/led.py
hardware backlight will repeat on and off
2. luma.examples libs install
if group does not exist, the following command will create it:
 $ sudo groupadd --system xxx
 $ cd luma.examples
install luma.core, luma.emulator, luma.lcd, luma.le-matrix, luma.oled pip libs, make sure this step without error or downloading interrupted, try again if get errors
 $ sudo -H pip install -e .
or
 $ sudo -H pip3 install -e .
for debian buster(python 3.7) which does not include /usr/bin/pip in package python3-pip, and will get the following errors when install luma packages with pip3
 Using UNIX configuration...
install sdl2 related packages to fix this issue, then install luma libs again with pip3
check installed luma pip libs
 $ pip3 list | grep luma
   luma.core          2.4.0
   luma.emulator      1.4.0
   luma.lcd           2.10.0
   luma.led-matrix    1.7.0
   luma.oled          3.11.0
3. examples test
 $ cd examples
HDMI LCD
Bananapi M2S Tested HDMI LCD
panel /boot/env.txt
Waveshare 3.5inch 480x320 hdmi_autodetect=no
hdmi=480x320p60hz
Waveshare 3.5inch 640x480
Waveshare 4inch 720x720
Waveshare 5inch 800x480
Waveshare 5.5inch 1440x2560 hdmi_autodetect=no
hdmi=1440x2560p60hz
Waveshare 7inch 800x480
Waveshare 7inch 1024x600
Waveshare 7.9inch 400x1280
Waveshare 8inch 1536x2048 hdmi_autodetect=no
hdmi=1536x2048p60hz
Waveshare 8.8inch 480x1920
Waveshare 9inch 2560x1600 hdmi_autodetect=no
hdmi=2560x1600p60hz
Waveshare 10.1inch 1024x600
Waveshare 10.1inch 1280x800
Waveshare 11.9inch 320x1480
Waveshare 13.3inch 1920x1080
Waveshare 15.6inch 1920x1080
backlight control
Boot Sequence
 Board ID = 1
 Set cpu clk to 24M
 Set clk81 to 24M
 Use GP1_pll as DSU clk.
 DSU clk: 1200 Mhz
 CPU clk: 1200 MHz
 Set clk81 to 166.6M
 board id: 1
 fw parse done
 PIEI prepare done
 fastboot data verify
 result: 255
 DDR4 probe
 Board ID = 1
 Set cpu clk to 24M
 Set clk81 to 24M
 DSU clk: 1200 Mhz
 CPU clk: 1200 MHz
 Set clk81 to 166.6M
 eMMC boot @ 0
 sw8 s
 board id: 1
 fw parse done
 PIEI prepare done
 00000000
 emmc switch 1 ok
 ddr saved addr:00016000
 00000000
   remount succeeded
   1234567890	fastboot
   OKAY [  0.044s]
   finished. total time: 0.044s
   OKAY [  0.047s]
   finished. total time: 0.047s
   erasing 'bootloader'...
   OKAY [  0.059s]
   finished. total time: 0.059s
   erasing 'bootloader-boot0'...
   OKAY [  0.036s]
   finished. total time: 0.036s
   erasing 'bootloader-boot1'...
   OKAY [  0.035s]
   finished. total time: 0.035s
   start = 0,end = 57343
   start = 221184,end = 30535679
   start = 0,end = 8191
   bananapi_m2s_v1#reset
   resetting ...
   BPI: try boot from sdcard
   reading boot.ini
   Starting boot.ini...
   reading env.txt
   HDMI: Autodetect: 1080p60hz
   reading Image.gz
   reading bananapi_m2s.dtb
   reading uInitrd
 $ sync
Wifi/BT support
1. Android test and support.
 rtl8723bu wifi/bt(usb)
 rtl8188eu wifi(usb)
 rtl8821cu wifi/bt(usb)
 rtl8822cs wifi/bt(sdio/uart)
How to enable Android Wifi/BT
2. Linux test and support.
 rtl8188eu wifi(usb)
 rtl8192eu wifi(usb)
 rtl8811au wifi(usb)
 rtl8812au wifi(usb)
 rtl8812bu wifi(usb)
How to enable Linux Wifi
SDIO/UART type:
2). Configure the dtb overlay
   overlays="wifi_bt_rtl8822cs"
 88x2cs
How to enable Linux Bluetooth
Cloud-init&Snap
or
 $ sudo apt purge cloud-init
2. disable or remove snap
 $ sudo apt purge snapd
Enable rc-local
 [Unit]
 After=network.target
 [Service]
 Type=forking
 ExecStart=/etc/rc.local start
 TimeoutSec=0
 RemainAfterExit=yes
 GuessMainPID=no
 [Install]
 WantedBy=multi-user.target
 Alias=rc-local.service
Create /etc/rc.local file.
 sudo nano /etc/rc.local
 #!/bin/sh
 # rc.local
 # value on error.
 # bits.
 exit 0
 $ sudo chmod +x /etc/rc.local
 $ sudo reboot
Enable sudo for Debian
 $ su root
 Password:(enter bananapi)
 # apt-get update
 # apt-get install sudo
 # adduser pi sudo
Install Docker Engine
1. Set up the repository
Set up the stable repository
 $  echo \
2. Install Docker Engine
 $ sudo docker run hello-world
