Getting Started with M2S
- 1 Introduction
- 2 specifications
- 3 development
- 3.1 Prepare
- 3.2 Android
- 3.3 Linux
- 3.3.1 Prepare
- 3.3.2 Install Image to SDcard
- 3.3.3 Install Image to EMMC
- 3.3.4 Build Linux Source Code
- 3.3.5 DTB overlay
- 3.3.6 Enable Camera
- 3.3.7 Switch Mipi Panel
- 3.3.8 Panel Rotation
- 3.3.9 WiringPi
- 3.3.10 RPi.GPIO
- 3.3.11 WiringPi2-Python
- 3.3.12 Luma.Examples
- 3.3.13 HDMI LCD
- 3.3.14 Custom Linux Boot Logo
- 3.4 Other Development
- Error creating thumbnail: Unable to save thumbnail to destination
Android DTB overlay
- How to apply a new dtbo
- 1. ADB command via sysfs
- 3. Settings App(To-Do)
Amlogic multi-dtb tool
Single dtb detected
find 2 dtbos
dtbos to be applied: 1
Apply dtbo 1
Install OpenGapps
- 2. Download device_id.apk.
- udisk:
- sdcard:
Switch Mipi Panel
Panel Rotation
- 1. UI Rotation in Settings->Display->Screen rotation
index 1f51703..d592a44 100644
else
ro.sf.lcd_density=213 \
endif
index 4a698b0..3d41b63 100755
@@ -876,8 +876,8 @@
reg = <0x5d>;
Custom Android Boot Logo
- 4. Extract this tool
- 8. The wiki guide is only for bananapi 4.9 bsp ubuntu/debian images.
$ sudo balena local flash path/to/xxx-bpi-m2s-xxx.img.zip $ sudo balena local flash path/to/xxx-bpi-m2s-xxx.img.zip --drive /dev/disk2 $ sudo balena local flash path/to/xxx-bpi-m2s-xxx.img.zip --drive /dev/disk2 --yes
$ sudo apt-get install pv unzip $ sudo unzip -p xxx-bpi-m2s-xxx.img.zip | pv | dd of=/dev/sdX bs=10M status=noxfer
$ sudo apt-get install pv unzip $ sudo bpi-copy xxx-bpi-m2s-xxx.img.zip /dev/sdX
$ sudo apt-get install pv unzip $ sudo unzip -p xxx-bpi-m2s-xxx.img.zip | pv | dd of=/dev/mmcblk0 bs=10M status=noxfer
$ sudo apt-get install pv unzip $ sudo bpi-copy xxx-bpi-m2s-xxx.img.zip /dev/mmcblk0
root@bananapi:~# ls /boot/overlays/ custom_ir.dtbo pwm_b-backlight.dtbo spi0.dtbo ds3231.dtbo pwm_c-beeper.dtbo uart1_cts_rts.dtbo hifi_pcm5102a.dtbo pwm_cd-c.dtbo uart1.dtbo hifi_pcm5122.dtbo pwm_cd.dtbo uart2.dtbo i2c1.dtbo pwm_ef.dtbo waveshare_tft24_lcd.dtbo i2c2.dtbo pwm_ef-f.dtbo waveshare_tft35c_lcd.dtbo pwm_ab.dtbo sdio.dtbo waveshare_tft35c_rtp.dtbo
Enable Camera
overlays="os08a10"
Switch Mipi Panel
Panel Rotation
Section "Device"
# Rotate off
# Option "Rotate" "off"
Option "Rotate" "CW"
# Option "Rotate" "UD"
# Option "Rotate" "CCW"
EndSection
Section "InputClass"
MatchIsTouchscreen "on"
MatchProduct "goodix-ts"
MatchDriver "libinput"
EndSection
$ sudo apt-get update $ sudo apt-get install build-essential git $ git clone https://github.com/Dangku/WiringPi $ cd WiringPi $ chmod a+x build $ sudo ./build
- 3. BPI GPIO Extend board and examples in WiringPi/examples
$ sudo apt-get update $ sudo apt-get install build-essential python3 python3-pip python3-dev python3-setuptools git $ git clone https://github.com/Dangku/RPi.GPIO-Amlogic.git $ cd RPi.GPIO-Amlogic $ sudo python3 setup.py clean --all $ sudo python3 setup.py install
WiringPi2-Python
$ sudo apt-get update $ sudo apt-get install build-essential python3 python3-dev python3-setuptools swig git $ git clone --recursive https://github.com/Dangku/WiringPi2-Python-Amlogic.git $ cd WiringPi2-Python-Amlogic $ sudo python3 setup.py install
Luma.Examples
- build bananapi m2s RPi.GPIO with python3 instead of python because luma uses python3.
$ sudo apt-get update $ sudo apt-get install build-essential python3 python3-dev python3-setuptools git $ git clone https://github.com/Dangku/RPi.GPIO-Amlogic.git $ cd RPi.GPIO-Amlogic $ sudo python3 setup.py clean --all $ sudo python3 setup.py install
$ sudo python3 test/led.py
$ sudo groupadd --system xxx
$ sudo -H pip install -e .
- or
$ sudo -H pip3 install -e .
- 3. examples test
HDMI LCD
Bananapi M2S Tested HDMI LCD panel /boot/env.txt Waveshare 3.5inch 480x320 hdmi_autodetect=no hdmi=480x320p60hz
Waveshare 3.5inch 640x480 Waveshare 4inch 720x720 Waveshare 5inch 800x480 Waveshare 5.5inch 1440x2560 hdmi_autodetect=no hdmi=1440x2560p60hz
Waveshare 7inch 800x480 Waveshare 7inch 1024x600 Waveshare 7.9inch 400x1280 Waveshare 8inch 1536x2048 hdmi_autodetect=no hdmi=1536x2048p60hz
Waveshare 8.8inch 480x1920 Waveshare 9inch 2560x1600 hdmi_autodetect=no hdmi=2560x1600p60hz
Waveshare 10.1inch 1024x600 Waveshare 10.1inch 1280x800 Waveshare 11.9inch 320x1480 Waveshare 13.3inch 1920x1080 Waveshare 15.6inch 1920x1080
- backlight control
Boot Sequence
Wifi/BT support
- 2. Linux test and support.
- How to enable Linux Wifi
- SDIO/UART type:
overlays="wifi_bt_rtl8822cs"
Cloud-init&Snap
- or
$ sudo apt purge cloud-init
- 2. disable or remove snap
$ sudo apt purge snapd
Enable rc-local
- Create /etc/rc.local file.
sudo nano /etc/rc.local
$ sudo chmod +x /etc/rc.local
Enable sudo for Debian
Install Docker Engine
- 1. Set up the repository
$ echo \
- 2. Install Docker Engine
$ sudo docker run hello-world
