BPI-M4 Berry development board stands as a powerful Single Board Computer (SBC), harnessing the capabilities of the Allwinner H618 System-on-Chip (SoC) to provide developers with impressive performance and a wealth of features. Similar to the Raspberry Pi 4b, the BPI-M4 Berry boasts comparable CPU prowess, 2G LPDDR4 memory and 8G eMMC, integrated WiFi and Bluetooth functionalities, and a familiar 40-pin header layout, alongside 4 USB interfaces and a GbE RJ45 port.
Characterized by its robust performance, versatile features, and remarkable image processing capabilities, stands as an exemplary SBC development platform for professionals within the embedded and computing industries. Equipped with 8GB eMMC flash storage, high-performance decoding and encoding capabilities, and an array of interface options, it caters to a wide spectrum of application domains, including media processing, IoT, and entertainment. Whether catering to novices or seasoned developers, the BPI-M4 Berry development board offers an ideal toolset for realizing creative visions and project objectives.
Allwinner H618, Quad-core ARM Cortex™-A53 processor
ARM Mali G31 GPU
WIFI & Bluetooth
2G LPDDR4 RAM
8G eMMC flash memory
1x USB2.0 Type-C OTG, 5V power supply
4x USB2.0 Type-A
1x HDMI 2.0a
1x 3.5mm Audio & TVE jack socket
1x GbE Ethernet port
Hardware Specification of Banana pi BPI-M4 Berry
CPU
Allwinner H618, Quad-core ARM Cortex™-A53 processor, 64-bit, up to 1.5GHz
GPU
ARM Mali G31 GPU
Memory
2 GB LPDDR4
Storage
8G eMMC flash
SD card
MicroSD card slot
Wireless
2.4G/5G WiFi and Bluetooth 4.2
Ethernet
1x GbE Ethernet port(supports PoE with add-on PoE HAT)
HDMI
1x full-size HDMI 2.0a (up to 4K@60Hz with HDR10, CEC, DDC, SCDC), HDMI digital Audio output
Audio
IR
1x CIR
USB
4x USB2.0 Type-A HOST, 1x USB2.0 Type-C OTG
40-pin header
28 pins GPIO and Power (+5V, +3.3V and GND)
Buttons
Reset, FEL and User
LED
Power Status and Activity status
Power
5V@3A via USB Type-C
Size
85x56 mm
Weight
60g
module
Raspberry Pi 4B
CPU
1.5GHz Quad-Core BroadcomBCM2711(Cortex A72)
H618,64 Bit Cortex™-A53 Quad-Core
GPU
500 MHz VideoCore Vl
ARM Mali G31 GPU
Memory
1-4GB DDR4
2GB LPDDR4(up to 4G)
Onboard Storage
MicroSD (TF) card
MicroSD (TF) card / MMC card slot ,eMMC 8GB
Network
10/100/1000 Ethernet
Onboard WIFI &BT
IEEE 802.11a/b/g/n/ac & BT5.0
IEEE 802.11a/b/g/n/ac & BT4.2
Display
HDMI
HDMI
Camera
CSI
N/A
Video Outputs
2*Micro-HDMI
HDMI 2.0a 4K@60fps
Audio Output
3.5 mm Jack and HDM
3.5 mm Jack and HDMI
Audio In
N/A
N/A
GPIO
40-PIN: PWM,GPIO,UART,I²C bus,I²S bus,SPI bus,+3.3v,+5v,ground. CAN bus
Remote
N/A
IR reciever
USB Ports
2*USB3.0+2USB2.0
2 * USB 2.0 1* USB Otg
Buttons
N/A
Reset button, User button, Uboot button
LED
Power led Status led
Power led Status led Wifi led
Power
DC 5V/3A
DC 5V/2A
Board Size
88mmx58mm
88mmx58mm
PIN define
Pin Num
Pin Name
ALT0
ALT1
ALT2
ALT3
3.3V
2
5V
3
PG16
UART2_RX
TWI4_SDA
4
5V
5
PG15
UART2_TX
TWI4_SCK
6
GND
7
PG19
PWM1
8
PG6
UART1_TX
9
GND
10
PG7
UART1_RX
11
PH2
UART5_TX
PWM2
12
PG11
H_I2S2_BCLK
13
PH3
UART5_RX
PWM1
14
GND
15
PG2
16
PG8
UART1_RTS
17
3.3V
18
PG9
UART1_CTS
19
PH7
UART2_RTS
H_I2S3_LRCK
SPI1_MOSI
20
GND
21
PH8
UART2_CTS
H_I2S3_DOUT0
SPI1_MISO
H_I2S3_DIN1
22
PG1
23
PH6
UART2_RX
H_I2S3_BCLK
SPI1_CLK
24
PH5
UART2_TX
H_I2S3_MCLK
SPI1_CS0
25
GND
26
PH9
H_I2S3_DIN0
SPI1_CS1
H_I2S3_DOUT1
27
PG18
UART2_CTS
TWI3_SDA
28
PG17
UART2_RTS
TWI3_SCK
29
PG3
30
GND
31
PG4
32
PG0
33
PG5
34
GND
35
PG12
H_I2S2_LRCK
36
PH4
37
PG10
H_I2S2_MCLK
38
PG14
H_I2S2_DIN0
H_I2S2_DOUT1
39
GND
40
PG13
H_I2S2_DOUT0
H_I2S2_DIN1
BPI-M4 Berry Debug UART
GND
2
UART0_RX
3
UART0_TX
Baidu Cloud: https://pan.baidu.com/s/1yMlLXauxZywujH8WkYqEcQ?pwd=8888 (pincode:8888)
Google Drive: https://drive.google.com/drive/folders/1qQxQik4GJjOF1aEOs9a1YVFxJBPlyFnc?usp=sharing
BPI-M4 Berry Schematic diagram
Baidu cloud: https://pan.baidu.com/s/18jV5XOVoECraDpSWlYd1iA?pwd=8888 (pincode: 8888)
Google drive: https://drive.google.com/file/d/1KAFmQuvXMsLBnQDVcm-svhN356vxdrFn/view?usp=sharing
Baidu cloud: https://pan.baidu.com/s/1lgmPfwqR-B9Pg7ET7NavKw?pwd=8888 (pincode: 8888)
Google drive: https://drive.google.com/file/d/1pQELD4uTexkHbvar-ArksAJ9TPj86HA1/view?usp=sharing
BPI-M4Berry-Android_20240429
Baidu cloud: https://pan.baidu.com/s/1SFwaz199hXgBsCcI0D1hlg?pwd=8888 (pincode:8888)
Google drive: https://drive.google.com/drive/folders/1kPdWuO5VBhvr-XIohHAqTDrk6mk8W1Z-?usp=sharing
2024-01-14-bananapi-m4berry-android12-box.img
Baidu Cloud: https://pan.baidu.com/s/1TxHK3re-n83OqxyRN063_g?pwd=8888 (pincode:8888)
Google Drive: https://drive.google.com/drive/folders/1HbhgXqBajDsA8esbMLRzHbddpAFOV-lS?usp=sharing
2024-01-14-bananapi-m4berry-android12.img
Baidu Cloud: https://pan.baidu.com/s/1htyoCTGtCGgKfGUwL3OuHQ?pwd=8888 (pincode:8888)
Google Drive: https://drive.google.com/drive/folders/1CQh4ZHjA1Na7jvAk2y1AEP8r8p0HIwx1?usp=sharing
20240327_Bpi-m4berry_1.0.2_debian11_bullseye_desktop_xfce_linux6.1.31
Baidu Cloud: https://pan.baidu.com/s/1DFuklrdgB1FfK0feh2Iskw?pwd=8888 (pincode:8888)
Google Drive: https://drive.google.com/file/d/1fwksjD8w17oZRsxIqjAXHUMviL9DkFNP/view?usp=sharing
20240327_Bpi-m4berry_1.0.2_debian11_bullseye_minimal_linux6.1.31
Baidu Cloud: https://pan.baidu.com/s/1fMurMeF5NoEnnThORMX4Hw?pwd=8888 (pincode:8888)
Google Drive: https://drive.google.com/file/d/1KofzlzsEjG2IwwoYRs6DN9bbkCNXW2OQ/view?usp=sharing
20240327_Bpi-m4berry_1.0.2_debian12_bookworm_desktop_xfce_linux6.1.31
Baidu Cloud: https://pan.baidu.com/s/1bZPgpFcurgYOjTIw1OExhQ?pwd=8888 (pincode:8888)
Google Drive: https://drive.google.com/file/d/1e27dd0WLRbZhiUfXnxlAW22FRuhJS8cm/view?usp=sharing
20240327_Bpi-m4berry_1.0.2_debian12_bookworm_minimal_linux6.1.31
Baidu Cloud: https://pan.baidu.com/s/1cR0s1kODTi3jOxylb2aDQQ?pwd=8888 (pincode:8888)
Google Drive: https://drive.google.com/file/d/1kp-HkS6R3twpPtfyiMhIVyb_oSIkNmxK/view?usp=sharing
20240327_Bpi-m4berry_1.0.2_ubuntu22.04_jammy_desktop_xfce_linux6.1.31
Baidu Cloud: https://pan.baidu.com/s/17FQ0ypGUIGRsGwFlFpCvbg?pwd=8888 (pincode:8888)
Google Drive: https://drive.google.com/file/d/15IpXunBV0hqCG39_Op2dqybEa6IajjBn/view?usp=sharing
20240327_Bpi-m4berry_1.0.2_ubuntu22.04_jammy_minimal_linux6.1.31
Baidu Cloud: https://pan.baidu.com/s/1xQn02wms3YP159N6keejoQ?pwd=8888 (pincode:8888)
Google Drive: https://drive.google.com/file/d/1iwMHm0oaat-3Jme82qQFHhk_DZzh7By2/view?usp=sharing
SINOVOIP Aliexpress shop: https://www.aliexpress.us/item/1005006212355480.html?spm
Bipai Aliexpress shop: https://www.aliexpress.us/item/1005006212128000.html?gatewayAdapt=glo2usa
Taobao Shop: https://item.taobao.com/item.htm?spm=a1z10.5-c-s.w4002-25059194413.11.489155c8Addsck&id=747425760994
OEM&ODM, please contact: [email protected]
