Getting Started with BPI-M6
Revision as of 01:47, 31 May 2024 by Squy (talk | contribs) (Linux)
Banana Pi BPI-M6 with Synaptics VS680
Banana Pi BPI-M6 is a new generation single board computer design , use Synaptics VS680 quad-core Cortex-A73 (2.1GHz) and One Cortex-M3 processor,Imagination GE9920 GPU.and NPU Up to 6 .75Tops. Onboard 4GB LPDDR4 memory and 16GB EMMC storage, and supports 4 USB 3.0 interface, a gigabit network port.onboard 1 HDMI-rx port and 1 Hdmi-tx port.
  • Synaptics VideoSmart VS680 quad-core Cortex-A73 (2.1GHz) and One Cortex-M3 processor
  • Imagination GE9920 GPU
  • NPU for AI up to 6 .75Tops
  • System Memory – 4GB LPDDR4
  • Storage – 16GB eMMC flash
  • Video Output – 1 HDMIin and 1 HDMIout
  • Expansion – 40-pin
  • Misc – Reset, Power, and U-boot button; power and activity LED’s;
  • M.2 Key E(PCIe + MIPI CSI)
1. Prepare a usb-serial cable(3.3V,Baud: 115200), a 5V/3A adaptor type-c power supply. The serial cable is used for console debug and type-c cable is used for android image download.
3. User name/password: pi/bananapi ,root/bananapi.
1. Download and install the SenarySocSystemTool for android image download via USB type-c on M6, only support windows.
1. Open SenarySocSystemTool.exe, click Browse, and select the eMMCimg folder where the image is located.
2. Press the USB button next to type-c and connect to the computer using the type-c cable.
3. Click to start burning, and then wait for the burning to complete.
4. After Burning successfull, press the RST key, Unplug the usb and connect to power supply adaptor to startup.
5. If you want to erase eMMC, you can repeat the above steps, but you need to click on Erase eMMC instead of starting the burn.
NOTE: Android images currently only support burning to EMMC.
Install Image to SD card
Install Image with Balena Etcher.
Click on "Flash from file" to select image.
Click on "Select target" to select USB device.
Click on "Flash!" Start burning.
After the image is burned, insert the SD card into the BPI-M6. Press and hold the SPI key while inserting the power supply.
HDMI
VS680 HDMI TX functional properties:
  • Support hdmi v2.1
  • Support up to 2160p@60 YUV444
  • Support up to 1080p@60 with 12b deep color
  • Support up to HDCP 2.2
  • Support HBR output
  • Support HDR10 and HLG
HDMI TX software configuration
VS680 currently uses two display frameworks, FB and DRM
Source code file for FB scheme:
syna-release/linux_5_4/drivers/video/syna/source/
Source code file for DBM scheme:
syna-release/linux_5_4/drivers/soc/berlin/modules/drm/
Enable the HDMI TX feature in the configuration file. The configuration file is located in the SDK's syna-release/configs/product/vs680_a0_android_baseline_evk/vs680_a0_android_baseline_evk_defconfig,with the following configuration:
Enable HDCP
 test_disp enable/disable hdcp
 test_disp setVersion 1 //set hdcp 1.4
 test_disp setVersion 2 //set hdcp 2.2
Resolution Configuration
Supported standards: CEA-861-E video format
Supported resolutions:
  • 3840x2160p60Hz/30Hz//24Hz
  • 1920x1200@60hz
  • 1920x1080p@60
  • 1280x700p@60
Configure resolution and format on the command line:
test_disp setformat[Display ID] [Resolution ID] [BitDepth] [Color fmt] [Aspect Ratio][tgID][vout_mode]
Examples:
 test_disp setformat 0 64 2 0
Ethernet
WiFi & BT
There are two ways to use WiFi & BT.
Purchase BPI-M6 CSI · WiFi accessories. Insert it into the M.2 Key E interface, and then insert a network card on the accessories.
WiFi&BT accessories using USB interface.
Camera
You can purchase BPI-M6 CSI · WiFi accessories.There are two CSI interfaces above.
