Banana Pi BPI-M5
Revision as of 16:41, 28 May 2024 by Sinovoip (talk | contribs) (Ubuntu)
BPI-M5 Introduction
Amlogic S905X3 Processor
BPI-M5 case design
  • Amlogic S905X3 64-bit Quad core Cortex-A55 (2.0xxGHz)
  • Mali-G31 GPU
  • 4GB LPDDR4
  • 16GB eMMC flash
  • 4 USB 3.0
  • 1 GbE ethernet
  • HDMI output
CPU Amlogic S905X3 64-bit Quad-Core Cortex-A55 (2.0xxGHz)
Memory 4 GB LPDDR4
USB ports USB 3.0 PORT (x4)
Size & Weight 85x56 mm, 48g
OS Android and Linux
SDIO interface Wifi&BT
  • WiFi&BT board, 802.11 a/b/g/n/ac 2T2R WiFi and Bluetooth 5.0 , support BPI-M5 and BPI-F2P
IR Yes Yes Yes N/A
BPI-M5 40PIN GPIO (CON2)
CON1-P02 VCC5V
CON1-P03 GPIOX_17 I2C_M2_SDA
CON1-P04 VCC5V
CON1-P05 GPIOX_18 I2C_M2_SCL
CON1-P07 GPIOX_5 SDIO_CMD
CON1-P08 GPIOX_12 UART_A_TX
CON1-P10 GPIOX_13 UART_A_RX
CON1-P11 GPIOX_3 SDIO_D3
CON1-P12 GPIOAO_8 TDMB_SCLK
CON1-P13 GPIOX_4 SDIO_CLK
CON1-P15 GPIOX_7 PWM_F
CON1-P16 GPIOX_0 SDIO_D0
CON1-P18 GPIOX_1 SDIO_D1
CON1-P19 GPIOX_8 PCM_DIN
CON1-P21 GPIOX_9 PCM_DOUT
CON1-P22 GPIOX_2 SDIO_D2
CON1-P23 GPIOX_11 PCM_CLK
CON1-P24 GPIOX_10 PCM_SYNC
CON1-P26 GPIOX_16 PWM_E
CON1-P27 GPIOA_14 I2C_M3_SDA
CON1-P28 GPIOA_15 I2C_M3_SCL
CON1-P29 GPIOX_14 UART_A_CTS
CON1-P31 GPIOX_15 UART_A_RTS
CON1-P32 GPIOX_19 PWM_B
CON1-P33 GPIOX_6 PWM_A
CON1-P35 GPIOAO_7 TDMB_FS
CON1-P36 GPIOH_5 SPDIF_IN
CON1-P37 GPIOAO_9 I2S_MCLK
CON1-P40 GPIOAO_4 TDMB_DOUT
BPI-M5 Debug UART(CON1)
CON2-P1 GND
CON2-P2 UART0-RX
CON2-P3 UART0-TX
BPI-M5 runs wiringpi gpio
  • BPI-M5/M2 PRO Android9 source code:
Baidu Cloud: https://pan.baidu.com/s/1TmmR_075b49lPSt1Phq0ag?pwd=8888 (pincode: 8888)
Google Drive:https://drive.google.com/drive/folders/1RuvazYcr46HKMvNBxSqQftdyWa0tK9f7?usp=share_link
Linux BSP source code
How to flash Android Image
  • 2024-04-29-bpi-m5-m2pro-tablet-android9.img
Baidu cloud: https://pan.baidu.com/s/1zPAUBgFyef3s4kx5Ajw2EA?pwd=8888 (pincode:8888)
Google drive: https://drive.google.com/drive/folders/1oslXfzDmcs0RMq5TFibUGjVmlBMHq2PW?usp=sharing
  • 2023-03-01 release, tablet variant image
Baidu Cloud: https://pan.baidu.com/s/1cjzNgiE0-XJhvZgY0tQuHg?pwd=8888 (pincode: 8888)
Google Drive:https://drive.google.com/drive/folders/144OU7NMTxLUqxNN2tXESgAoE3VXYgA_F?usp=share_link
  • 2023-03-01 release, box variant image
Baidu Cloud:https://pan.baidu.com/s/1SAfGM0WxOHW0vYCkjQUfbQ?pwd=8888 (pincode: 8888)
Google Drive:https://drive.google.com/drive/folders/1Ipg8vZvKN_0xX0Fu24BW5UcDAHGhP7oH?usp=share_link
How to flash Linux Image
  • 2023-08-30-ubuntu-20.04-server-bpi-m5-m2pro-aarch64-sd-emmc.img
Baidu Cloud: https://pan.baidu.com/s/16nAyyW0IfTJqoYat2Qfcag?pwd=8888 (pincode:8888)
Google Drive:https://drive.google.com/drive/folders/1y3i9uUgzmp03r9zzeuJkNszPZNl7D0OR?usp=sharing
  • 2023-08-30-ubuntu-20.04-mate-desktop-bpi-m5-m2pro-aarch64-sd-emmc.img
Baidu Cloud: https://pan.baidu.com/s/1MeXrg3eQZ6qf0_RiUrffrg?pwd=8888 (pincode:8888)
Google Drive: https://drive.google.com/drive/folders/1PTxZVbcJHptHrU9kMkKnnt2CR80eEfRe?usp=sharing
  • 2023-08-30-debian-10-buster-xfce-bpi-m5-m2pro-aarch64-sd-emmc.img
Baidu Cloud: https://pan.baidu.com/s/15XHAZKDFqJLA3BH1b9Slqw?pwd=8888 (pincode:8888)
Google Drive:https://drive.google.com/drive/folders/1EDXxJs23xV5Je91ZhfPYDvBubhhmJN1n?usp=sharing
  • 2023-08-30-debian-10-buster-bpi-m5-m2pro-aarch64-sd-emmc.img
Baidu Cloud: https://pan.baidu.com/s/1tFUbyPbrTJ5UGgM05w2k6A?pwd=8888 (pincode:8888)
Google Drive:https://drive.google.com/drive/folders/1Y-GuZYovWRgBvt0z7FLnIuBJufVFflvv?usp=sharing
Third part image
Raspbian
  • BPI-M5 BPI-M2 Pro new image:Raspbian image, 2023-05-03 update,please choose the right image
Google driver: https://drive.google.com/drive/folders/1Rvr1l3LhnVcss0FD0_bAm3Jbi84vZBkT
Baidu Cloud : https://pan.baidu.com/s/1T2DT3ruTRvRdFgIUrR1obg?pwd=8888 (pincode:8888)
  • BPI-M5 BPI-M2 Pro new image:Raspbian image, 2022-4-09 update, Raspbian image for linux kernel 4.9 and 5.17. support 32bit and 64 bit,please choose the right image
Google driver: https://drive.google.com/drive/folders/1VoiHH0IMU5iZRRdGg1-SpSu8pmwnjkmX
Baidu Cloud: https://pan.baidu.com/s/1Y1S05nGQDOP8Pxu9eE6k_Q?pwd=8888
  • Image From Armbian Official website
https://www.armbian.com/bananapi-m5/
  • Image From Bananapi Released on 2023-03-13, build from Armbian main branch source code, fix some bugs and support i2c, uart, spi and rtl8822cs overlays, you can enable the overlay in /boot/armbianEnv.txt
Baidu Cloud: https://pan.baidu.com/s/1Wgg_0Z7Db6DSKqoIjf16PQ?pwd=8888 (pincode: 8888)
Google Drive: https://drive.google.com/drive/folders/1Yds8Rru_26S0wN2B-pIM6XkyxUXiceNl?usp=share_link
  • Armbian legacy build with bananapi kernel 4.9
EmuELEC
CoreELEC
Volumio
Download:
Odroid Android image
  • Base on Odroid android source code and build for bananapi m5/m2pro
Download:
  • Odroid ubuntu IMG for BPI-M5:
https://forum.banana-pi.org/t/odroid-ubuntu-img-for-bpi-m5/12169
Ubuntu Core 20
Download:
Baidu cloud :
Archlinux
Download:
HuaWei OpenEuler
Download:
Manjaro for BPI-M5
How to install Ubuntu Server 20.04 to M5 EMMC
