Banana Pi BPI-M5
BPI-M5 Introduction
- Mali-G31 GPU
- 4GB LPDDR4
- 16GB eMMC flash
- 4 USB 3.0
- 1 GbE ethernet
- HDMI output
CPU | Amlogic S905X3 64-bit Quad-Core Cortex-A55 (2.0xxGHz) | ||
Memory | 4 GB LPDDR4 | ||
Size & Weight | 85x56 mm, 48g | ||
OS | Android and Linux |
SDIO interface Wifi&BT
- WiFi&BT board, 802.11 a/b/g/n/ac 2T2R WiFi and Bluetooth 5.0 , support BPI-M5 and BPI-F2P
- how to use : https://wiki.banana-pi.org/Getting_Started_with_M5/M2Pro#Wifi.2FBT_support
- RT8822CS Bluetooth and WiFi adapter for Banana Pi BPI-M5:https://www.magazinmehatronika.com/en/rt8822cs-bluetooth-and-wifi-adapter-for-banana-pi-m5/?fbclid=IwAR0Oqm4TCa2SAXBTMJgRmWMJI-VQREqFxLh1-LnT_XzA5MAvYh_BL9-L7Xk
BPI-M5 40PIN GPIO (CON2)
CON1-P01 | VCC-3V3 | ||
CON1-P02 | VCC5V | ||
CON1-P04 | VCC5V | ||
CON1-P06 | GND | ||
CON1-P09 | GND | ||
CON1-P14 | GND | ||
CON1-P15 | GPIOX_7 PWM_F | ||
CON1-P17 | VCC-3V3 | ||
CON1-P20 | GND | ||
CON1-P25 | GND | ||
CON1-P30 | GND | ||
CON1-P33 | GPIOX_6 PWM_A | ||
CON1-P34 | GND | ||
CON1-P37 | GPIOAO_9 | I2S_MCLK | |
CON1-P39 | GND | ||
BPI-M5 Debug UART(CON1)
CON2-P1 | GND |
CON2-P2 | UART0-RX |
CON2-P3 | UART0-TX |
BPI-M5 runs wiringpi gpio
- BPI-M5/M2 PRO Android9 source code:
- Baidu Cloud: https://pan.baidu.com/s/1TmmR_075b49lPSt1Phq0ag?pwd=8888 (pincode: 8888)
- Google Drive:https://drive.google.com/drive/folders/1RuvazYcr46HKMvNBxSqQftdyWa0tK9f7?usp=share_link
Linux BSP source code
- BPI-M5 schematic diagram
- BPI-M5 PCB DXF file
- Amlogic S905x3 datasheet
- BANANA Pi BPI-M5 REVIEW & BENCHMARKS:https://bret.dk/banana-pi-m5-review/
- BANANA Pi M5 VS RASPBERRY Pi 4 – BENCHMARKS : https://bret.dk/banana-pi-m5-vs-raspberry-pi-4/
- BPI-M5 How to install Ubuntu server on external USB-disk:https://forum.banana-pi.org/t/bpi-m5-howto-install-ubuntu-server-on-external-usb-disk/15259
- Install Armbian, OctoPrint and Klipper on the emmc of a Banana pi M5 - Linux and windows : https://www.youtube.com/watch?v=q5I6pzWCTrg
- CoreELEC for Banana Pi BPI-M2 Pro and BPI-M5:https://wiki.coreelec.org/coreelec:bpi
- U-Boot for BananaPi BPI-M2-PRO (S905X3):https://u-boot.readthedocs.io/en/latest/board/amlogic/bananapi-m2pro.html
- How to flash Armbian to the eMMc of the Banana-Pi BPi-M5:https://uglyscale.press/2023/08/31/how-to-flash-armbian-to-emmc-of-banana-pi-bpi-m5/
- 2024-04-29-bpi-m5-m2pro-tablet-android9.img
- Baidu cloud: https://pan.baidu.com/s/1zPAUBgFyef3s4kx5Ajw2EA?pwd=8888 (pincode:8888)
- Google drive: https://drive.google.com/drive/folders/1oslXfzDmcs0RMq5TFibUGjVmlBMHq2PW?usp=sharing
- 2023-03-01 release, tablet variant image
- Baidu Cloud: https://pan.baidu.com/s/1cjzNgiE0-XJhvZgY0tQuHg?pwd=8888 (pincode: 8888)
- 2023-03-01 release, box variant image
- 2023-08-30-ubuntu-20.04-server-bpi-m5-m2pro-aarch64-sd-emmc.img
- Baidu Cloud: https://pan.baidu.com/s/16nAyyW0IfTJqoYat2Qfcag?pwd=8888 (pincode:8888)
- Google Drive:https://drive.google.com/drive/folders/1y3i9uUgzmp03r9zzeuJkNszPZNl7D0OR?usp=sharing
- 2023-08-30-ubuntu-20.04-mate-desktop-bpi-m5-m2pro-aarch64-sd-emmc.img
- Baidu Cloud: https://pan.baidu.com/s/1UgfUDdNE-SQHka64mrNAYw?pwd=8888 (pincode:8888)
- Google Drive:https://drive.google.com/drive/folders/1RMX8F1PMLO-UcPPJL4QwYvdPVhk-a_c_?usp=sharing
- 2023-08-30-debian-10-buster-xfce-bpi-m5-m2pro-aarch64-sd-emmc.img
- Baidu Cloud: https://pan.baidu.com/s/15XHAZKDFqJLA3BH1b9Slqw?pwd=8888 (pincode:8888)
- Google Drive:https://drive.google.com/drive/folders/1EDXxJs23xV5Je91ZhfPYDvBubhhmJN1n?usp=sharing
- 2023-08-30-debian-10-buster-bpi-m5-m2pro-aarch64-sd-emmc.img
- Baidu Cloud: https://pan.baidu.com/s/1tFUbyPbrTJ5UGgM05w2k6A?pwd=8888 (pincode:8888)
- Google Drive:https://drive.google.com/drive/folders/1Y-GuZYovWRgBvt0z7FLnIuBJufVFflvv?usp=sharing
Third part image
Raspbian
- BPI-M5 BPI-M2 Pro new image:Raspbian image, 2023-05-03 update,please choose the right image
- Google driver: https://drive.google.com/drive/folders/1Rvr1l3LhnVcss0FD0_bAm3Jbi84vZBkT
- Baidu Cloud : https://pan.baidu.com/s/1T2DT3ruTRvRdFgIUrR1obg?pwd=8888 (pincode:8888)
- BPI-M5 BPI-M2 Pro new image:Raspbian image, 2022-4-09 update, Raspbian image for linux kernel 4.9 and 5.17. support 32bit and 64 bit,please choose the right image
- Google driver: https://drive.google.com/drive/folders/1VoiHH0IMU5iZRRdGg1-SpSu8pmwnjkmX
- Baidu Cloud: https://pan.baidu.com/s/1Y1S05nGQDOP8Pxu9eE6k_Q?pwd=8888
- discuss on forum : https://forum.banana-pi.org/t/bpi-m5-bpi-m2-pro-new-image-rasbian-image-2022-4-09-update/13246
- Image From Armbian Official website
- Image From Bananapi Released on 2023-03-13, build from Armbian main branch source code, fix some bugs and support i2c, uart, spi and rtl8822cs overlays, you can enable the overlay in /boot/armbianEnv.txt
- Armbian legacy build with bananapi kernel 4.9
EmuELEC
- This is a porting of EmuELEC v4.5 for BPI-M5. I ported from odroid c4 official EmuELEC image. PS3 a XBOX ONE S gamepad controllers were tested and work fine.
- https://forum.banana-pi.org/t/emuelec-for-bpi-m5/12095
CoreELEC
Volumio
- Download:
Odroid Android image
- Download:
Ubuntu Core 20
- Download:
- Baidu cloud :
Archlinux
- Download:
HuaWei OpenEuler
- Download:
Manjaro for BPI-M5
How to install Ubuntu Server 20.04 to M5 EMMC
- SINOVOIP Aliexpress shop: https://www.aliexpress.us/item/3256801685527943.html?
- Bipai Aliexpress shop: https://www.aliexpress.us/item/3256803496172400.html
- Taobao Shop: https://item.taobao.com/item.htm?spm=a1z10.1-c-s.w4004-25059194388.8.13c23a90voeqk3&id=636199832159
- Mass order,please contact : judyhuang@banana-pi.com
