Banana Pi BPI-M6
Revision as of 18:07, 8 March 2024 by Sinovoip (talk | contribs)
Banana Pi BPI-M6 with Synaptics VS680
Banana Pi BPI-M5 Amlogic S905X3 Processor
Banana Pi BPI-M4 Realtek RTD1395
Banana Pi BPI-M64 Allwinner A64
Banana Pi BPI-M2+ Allwinner H3/H5/H2+]3
About VideoSmart VS680
VS680 chip official Developer Center: https://developer.senarytech.com/index.html
  • Synaptics VideoSmart VS680 quad-core Cortex-A73 (2.1GHz) and One Cortex-M3 processor
  • Imagination GE9920 GPU
  • NPU for AI up to 6 .75Tops
  • 4GB LPDDR4
  • 16GB eMMC flash
  • M.2 Key E(PCIe + MIPI CSI)
  • 4 USB 3.0
  • 1 GbE ethernet
  • 1 HDMIin and 1 HDMIout
HardWare Specification of Banana pi BPI-M6
CPU Synaptics VS680 quad-core Cortex-A73 (2.1GHz) and One Cortex-M3 processor
GPU Imagination GE9920 GPU
NPU for AI Up to 6 .75Tops
Memory 4 GB LPDDR4
Video 1 x HDMI 2.1 (up to 4K@60Hz with HDR, CEC, EDID) out, and 1 HDMI in Port
Display MIPI DSI interface
M.2 interface M.2 Key E(PCIe + MIPI CSI)
USB ports USB 3.0 PORT (x4)
Switches SPI boot and U-boot
Power Source 5 volt @3A TYPE C
Size & Weight 92x60mm, 48g
OS Android and Linux
40PIN Header(CON3)
BPI-M6 40PIN Header(CON3)
BPI-M6-CON3 PIN PIN BPI-M6-CON3
PWR_3V3_CTL 1 2 PWR_5V
GPIO46/TW0_SDA 3 4 PWR_5V
GPIO47/TW0_SCL 5 6 GND
GPIO53/PWM1 7 8 SM_GPIO15/UART2_TXD
GND 9 10 SM_GPIO14/UART2_RXD
GPIO36/PWM3 11 12 GPIO20/I2S1_BCLK
GPIO37/PWM2 13 14 GND
EXPANDER_TW3_GPIO1_4 15 16 EXPANDER_TW3_GPIO1_0
PWR_3V3_CTL 17 18 EXPANDER_TW3_GPIO1_1
SM_GPIO13/SPI2_SDO/URT2_RTS/SM_STRAP1 19 20 GND
SM_GPIO12/SPI2_SDI/URT2_CTS 21 22 GPIO4/SPDIF
SM_GPIO11/SPI2_SCK 23 24 SM_GPIO17/SPI2_SS0/SM_STRAP2
GND 25 26 SM_GPIO16/SPI2_SS1/SM_STRAP3
GPIO15/I2S1_DO3 27 28 GPIO16/I2S1_DO2
EXPANDER_TW3_GPIO1_7 29 30 GND
EXPANDER_TW3_GPIO1_6 31 32 EXPANDER_TW3_GPIO1_3
EXPANDER_TW3_GPIO1_5 33 34 GND
GPIO21/I2S1_LRCK 35 36 EXPANDER_TW3_GPIO1_2
GPIO18/I2S1_MCLK 37 38 GPIO17/I2S1_DO1
GND 39 40 GPIO19/I2S1_DO0
M.2 E-KEY(CN10)
BPI-M6 M.2 E-KEY(CN10)
PIN PIN
GND 1 2 VCC-NGFF
NGFF_KEYE_DP 3 4 VCC-NGFF
NGFF_KEYE_DM 5 6 WiFi-LED
GND 7 8 SM_GPIO10/TW3_SDA
MIPI_CSI0_RD0p 9 10 SM_GPIO9/TW3_SCL
MIPI_CSI0_RD0n 11 12 NI
MIPI_CSI0_RD1p 13 14 BT-LED
MIPI_CSI0_RD1n 5 16 BT-LED
MIPI_CSI0_RD2p 17 18 GND
MIPI_CSI0_RD2n 19 20 SM_GPIO6/UART_WAKE#Puboot
MIPI_CSI0_RD3p 21 22 GPIO43/UART3_RXD
MIPI_CSI0_RD3n 23 24 NOTCH
NOTCH 25 26 NOTCH
NOTCH 27 28 NOTCH
NOTCH 29 30 NOTCH
NOTCH 31 32 GPIO42/UART3_TXD
GND 33 34 GPIO41/UART3_CTSn
PCIe_TX0p 35 36 GPIO40/UART3_RTSn
PCIe_TX0n 37 38 NI
GND 39 40 MIPI_CSI0_RCKp
PCIe_RX0p 41 42 MIPI_CSI0_RCKn
PCIe_RX0n 43 44 NI
GND 45 46 NI
PCIe_CLKp 47 48 NI
PCIe_CLKn 49 50 CLK32_OUT
GND 51 52 PCIE_PERSTn
PCIE_CLKREQ 53 54 GPIO10/DISABLE_BT
PCIE_PEWAKE 55 56 GPIO09/DISABLE_WiFi
GND 57 58 GPIO46/TW0_SDA(VDDIO_1.8V)
PCIe_TX1p 59 60 GPIO47/TW0_SCL(VDDIO_1.8V)
PCIe_TX1n 61 62 NI
GND 63 64 MIPI_CSI1_RD0p
PCIe_RX1p 65 66 MIPI_CSI1_RD0n
PCIe_RX1n 67 68 MIPI_CSI1_RD1p
GND 69 70 MIPI_CSI1_RD1n
MIPI_CSI1_RCKp 71 72 VCC-NGFF
MIPI_CSI1_RCKn 73 74 VCC-NGFF
GND 75
MIPI DSI(CN12)
BPI-M6 MIPI DSI(CN12)
CN12-P1 MIPI_DSI_TX1_D0n
CN12-P2 MIPI_DSI_TX1_D0p
CN12-P3 MIPI_DSI_TX1_D1n
CN12-P4 MIPI_DSI_TX1_D1p
CN12-P5 MIPI_DSI_TX1_CLKn
CN12-P6 MIPI_DSI_TX1_CLKp
CN12-P7 MIPI_DSI_TX1_D2n
CN12-P8 MIPI_DSI_TX1_D2p
CN12-P9 MIPI_DSI_TX1_D3n
CN12-P10 MIPI_DSI_TX1_D3p
CN12-P11 GND
CN12-P12 LCD_ADC
CN12-P13 GPIO2/LCD1_PWR_EN(VDDIO_1.8V)
CN12-P14 GPIO3/LCD1_RST(VDDIO_1.8V)
CN12-P15 GPIO39/LCD1_BL_PWM(VDDIO_1.8V)
CN12-P16 GND
CN12-P17 GPIO0/TP_INT(VDDIO_1.8V)
CN12-P18 GPIO1/TP_RST(VDDIO_1.8V)
CN12-P19 GPIO47/TW0_SCL(VDDIO_1.8V)
CN12-P20 GPIO46/TW0_SDA(VDDIO_1.8V)
CN12-P21 GND
CN12-P22 GND
CN12-P23 PWR_5V
CN12-P24 PWR_5V
Debug UART(CON2)
BPI-M6 Debug UART(CON2)
CON2-P1 GND
CON2-P2 UART0-RX
CON2-P3 UART0-TX
Source code on github
Armbian Source code:
Linux Source code:
  • BPI-M6 VS680 SOC System Tool Manual V1.3.2.1
Baidu Cloud: https://pan.baidu.com/s/1tX7UVSJQOcNhMlazQRQkpw?pwd=8888 (pincode:8888)
Google Drive: https://drive.google.com/file/d/1gQalGLqNN24TeTBmJGzS0e3HeXxRD1fP/view?usp=sharing
  • BPI-M6 schematic diagram
Baidu Cloud: https://pan.baidu.com/s/18VTAdGtQFb2nu1bku8mHBw?pwd=8888 (pincode:8888)
Google Drive: https://drive.google.com/file/d/1z-o5dZWcYrmTqNH3Wz9ttWUzptveCS6s/view?usp=sharing
  • BPI-M6 DXF File:
Baidu Cloud: https://pan.baidu.com/s/1Ngc11CcnufAdDcdwMd2mmQ?pwd=8888 (pincode:8888)
Google Drive: https://drive.google.com/file/d/1HJmpC5L3YqrJt4IsN0SMD5HoowqfGCyU/view?usp=sharing
  • 2023-08-30 release aosp_dolphin_tablet-syna-image-lpddr4x
Baidu Cloud: https://pan.baidu.com/s/1unEibD-NI8-Ti5le2E6d7g?pwd=8888 (pincode:8888)
Google Drive:https://drive.google.com/file/d/1egPBOusdlNGJDdp5muAjiv2MvMya0F-H/view?usp=sharing
  • 2024-02-29-Armbian-unofficial_24.2.0-trunk_Bananapim6_bookworm_legacy_5.4.195_xfce_desktop.img
Baidu cloud: https://pan.baidu.com/s/1NqAxVm4XXUh95T8a7MI6lg?pwd=8888 (pincode:8888)
Google drive: https://drive.google.com/file/d/1VDo5q2YCku3ozSQSSR9sbMnIryxwavR6/view?usp=sharing
  • 2024-02-29-Armbian-unofficial_24.2.0-trunk_Bananapim6_bookworm_legacy_5.4.195.img
Baidu cloud: https://pan.baidu.com/s/1cvj-rhe9ilbD6UQdxP55RQ?pwd=8888 (pincode:8888)
Google drive: https://drive.google.com/file/d/1JaRUZuSbrAHKykfjVsbrmoOaOQwRPKXV/view?usp=sharing
  • 2024-02-29-Armbian-unofficial_24.2.0-trunk_Bananapim6_bullseye_legacy_5.4.195_xfce_desktop.img
Baidu cloud: https://pan.baidu.com/s/1nxF_DtdgjL5Qey9_FA3KlA?pwd=8888 (pincode:8888)
Google drive: https://drive.google.com/file/d/1o6d3TFDf_sNd5yxSHR0p7FDf60eSZzEA/view?usp=sharing
  • 2024-02-29-Armbian-unofficial_24.2.0-trunk_Bananapim6_bullseye_legacy_5.4.195.img
Baidu cloud: https://pan.baidu.com/s/1vmSHl0Kb58Qd9m5VE8waJg?pwd=8888 (pincode:8888)
Google drive:https://drive.google.com/file/d/1o6d3TFDf_sNd5yxSHR0p7FDf60eSZzEA/view?usp=sharing
  • 2024-02-29-Armbian-unofficial_24.2.0-trunk_Bananapim6_buster_legacy_5.4.195_xfce_desktop.img
Baidu cloud: https://pan.baidu.com/s/1rdnURH86CgGRzVoHpOofkQ?pwd=8888 (pincode:8888)
Google drive: https://drive.google.com/file/d/12m47cuQaIflDHBk1wt4x87A0lDsTEOpW/view?usp=sharing
  • 2024-02-29-Armbian-unofficial_24.2.0-trunk_Bananapim6_buster_legacy_5.4.195.img
Baidu cloud: https://pan.baidu.com/s/1Aq0v_55RyRbB0-Pn_0x8cA?pwd=8888 (pincode:8888)
Google drive: https://drive.google.com/file/d/12UFB7uCao1ZOUGBdZAY2B4X4GDSs0vfB/view?usp=sharing
  • 2024-02-29-Armbian-unofficial_24.2.0-trunk_Bananapim6_jammy_legacy_5.4.195_xfce_desktop.img
Baidu cloud: https://pan.baidu.com/s/12__shynadQvMNKjKETe-Hg?pwd=8888 (pincode:8888)
Google drive: https://drive.google.com/file/d/1Ek82kEKs1S9psevPvIfvqBmdm7u0K1qa/view?usp=sharing
  • 2024-02-29-Armbian-unofficial_24.2.0-trunk_Bananapim6_jammy_legacy_5.4.195.img
Baidu cloud: https://pan.baidu.com/s/1EuIrdU66PZ_sPIIAmOo9Lw?pwd=8888 (pincode:8888)
Google drive: https://drive.google.com/file/d/1jMZiTfXnVcezjmqdGViuXpBfVwMGTrPH/view?usp=sharing
  • 2024-02-29-Armbian-unofficial_24.2.0-trunk_Bananapim6_lunar_legacy_5.4.195.img
Baidu cloud: https://pan.baidu.com/s/1dAdvSxe44c19pdA9YypohA?pwd=8888 (pincode:8888)
Google drive: https://drive.google.com/file/d/1aS9daYUWtFX5zMxnoC30ze-ds0BeJKj2/view?usp=sharing
  • 2024-02-29-Armbian-unofficial_24.2.0-trunk_Bananapim6_mantic_legacy_5.4.195_xfce_desktop.img
Baidu cloud: https://pan.baidu.com/s/14xDy88eS_3yVqMR6IghULg?pwd=8888 (pincode:8888)
Google drive: https://drive.google.com/file/d/1hE83uX5xEaDIb5OpTJE7pBHVnm6FmW14/view?usp=sharing
  • 2024-02-29-Armbian-unofficial_24.2.0-trunk_Bananapim6_mantic_legacy_5.4.195.img
Baidu cloud: https://pan.baidu.com/s/1adQHrBT_b3guU1p2aTp18A?pwd=8888 (pincode:8888)
Google drive: https://drive.google.com/file/d/1vmZGEqTnAik65vMiRpRcl_KFcBuOmLhA/view?usp=sharing
Google Drive: https://drive.google.com/file/d/1-S69RDEA0KmSxiCrfT5uePVg6hoHMUN3/view?usp=sharing
  • 2024-02-29-Armbian-unofficial_24.2.0-trunk_Bananapim6_focal_legacy_5.4.195.img
Baidu cloud: https://pan.baidu.com/s/1J4M5Pc35djr7waPpzeTVDA?pwd=8888 (pincode:8888)
Google drive: https://drive.google.com/file/d/1diKkpHhmhA5Xh5uJnHuDT27P4DLWcp3l/view?usp=sharing
  • 2024-01-25-ubuntu-20.04-mate-desktop-vpu-npu-bpi-m6-aarch64-sd.img
Baidu Cloud: https://pan.baidu.com/s/1IUDdKI0lT53-jFqUgqrdGA?pwd=8888 (pincode:8888)
Google Drive: https://drive.google.com/file/d/1mw0Fiwa0fmXyTs6c6DI9Z4bcQZEy83p2/view?usp=sharing
