About VideoSmart VS680
- Synaptics VideoSmart VS680 quad-core Cortex-A73 (2.1GHz) and One Cortex-M3 processor
- Imagination GE9920 GPU
- NPU for AI up to 6 .75Tops
- 4GB LPDDR4
- 16GB eMMC flash
- M.2 Key E(PCIe + MIPI CSI)
- 4 USB 3.0
- 1 GbE ethernet
- 1 HDMIin and 1 HDMIout
HardWare Specification of Banana pi BPI-M6
CPU |
GPU |
NPU for AI |
Up to 6 .75Tops
Memory |
4 GB LPDDR4
Storage |
MicroSD slot with support for up to 256GB expansion and 16G eMMC flash with support for up to 64GB
Network |
10/100/1000 Mbit/s Ethernet ,Optional WiFi USB dongle
Video |
1 x HDMI 2.1 (up to 4K@60Hz with HDR, CEC, EDID) out, and 1 HDMI in Port
Audio Output(s) |
1 x HDMI digital output
Display |
MIPI DSI interface
M.2 interface |
USB ports |
USB 3.0 PORT (x4)
GPIO |
40 Pin Header : GPIO (x28) and Power (+5V, +3.3V and GND). GPIO pins can be used for UART, I2C, SPI or PWM
Switches |
SPI boot and U-boot
LED |
Power Status and Activity status
Power Source |
5 volt @3A TYPE C
Size & Weight |
92x60mm, 48g
OS |
Android and Linux
BPI-M6 40PIN Header(CON3)
BPI-M6-CON3 |
PIN |
PIN |
BPI-M6-CON3
PWR_3V3_CTL |
1 |
2 |
PWR_5V
GPIO46/TW0_SDA |
3 |
4 |
PWR_5V
GPIO47/TW0_SCL |
5 |
6 |
GND
GPIO53/PWM1 |
7 |
8 |
SM_GPIO15/UART2_TXD
GND |
9 |
10 |
SM_GPIO14/UART2_RXD
GPIO36/PWM3 |
11 |
12 |
GPIO20/I2S1_BCLK
GPIO37/PWM2 |
13 |
14 |
GND
EXPANDER_TW3_GPIO1_4 |
15 |
16 |
EXPANDER_TW3_GPIO1_0
PWR_3V3_CTL |
17 |
18 |
EXPANDER_TW3_GPIO1_1
SM_GPIO13/SPI2_SDO/URT2_RTS/SM_STRAP1 |
19 |
20 |
GND
SM_GPIO12/SPI2_SDI/URT2_CTS |
21 |
22 |
GPIO4/SPDIF
SM_GPIO11/SPI2_SCK |
23 |
24 |
SM_GPIO17/SPI2_SS0/SM_STRAP2
GND |
25 |
26 |
SM_GPIO16/SPI2_SS1/SM_STRAP3
GPIO15/I2S1_DO3 |
27 |
28 |
GPIO16/I2S1_DO2
EXPANDER_TW3_GPIO1_7 |
29 |
30 |
GND
EXPANDER_TW3_GPIO1_6 |
31 |
32 |
EXPANDER_TW3_GPIO1_3
EXPANDER_TW3_GPIO1_5 |
33 |
34 |
GND
GPIO21/I2S1_LRCK |
35 |
36 |
EXPANDER_TW3_GPIO1_2
GPIO18/I2S1_MCLK |
37 |
38 |
GPIO17/I2S1_DO1
GND |
39 |
40 |
GPIO19/I2S1_DO0
M.2 E-KEY(CN10)
BPI-M6 M.2 E-KEY(CN10)
PIN |
PIN
GND |
1 |
2 |
VCC-NGFF
NGFF_KEYE_DP |
3 |
4 |
VCC-NGFF
NGFF_KEYE_DM |
5 |
6 |
WiFi-LED
GND |
7 |
8 |
SM_GPIO10/TW3_SDA
MIPI_CSI0_RD0p |
9 |
10 |
SM_GPIO9/TW3_SCL
MIPI_CSI0_RD0n |
11 |
12 |
NI
MIPI_CSI0_RD1p |
13 |
14 |
BT-LED
MIPI_CSI0_RD1n |
5 |
16 |
BT-LED
MIPI_CSI0_RD2p |
17 |
18 |
GND
MIPI_CSI0_RD2n |
19 |
20 |
SM_GPIO6/UART_WAKE#Puboot
MIPI_CSI0_RD3p |
21 |
22 |
GPIO43/UART3_RXD
MIPI_CSI0_RD3n |
23 |
24 |
NOTCH
NOTCH |
25 |
26 |
NOTCH
NOTCH |
27 |
28 |
NOTCH
NOTCH |
29 |
30 |
NOTCH
NOTCH |
31 |
32 |
GPIO42/UART3_TXD
GND |
33 |
34 |
GPIO41/UART3_CTSn
PCIe_TX0p |
35 |
36 |
GPIO40/UART3_RTSn
PCIe_TX0n |
37 |
38 |
NI
GND |
39 |
40 |
MIPI_CSI0_RCKp
PCIe_RX0p |
41 |
42 |
MIPI_CSI0_RCKn
PCIe_RX0n |
43 |
44 |
NI
GND |
45 |
46 |
NI
PCIe_CLKp |
47 |
48 |
NI
PCIe_CLKn |
49 |
50 |
CLK32_OUT
GND |
51 |
52 |
PCIE_PERSTn
PCIE_CLKREQ |
53 |
54 |
GPIO10/DISABLE_BT
PCIE_PEWAKE |
55 |
56 |
GPIO09/DISABLE_WiFi
GND |
57 |
58 |
GPIO46/TW0_SDA(VDDIO_1.8V)
PCIe_TX1p |
59 |
60 |
GPIO47/TW0_SCL(VDDIO_1.8V)
PCIe_TX1n |
61 |
62 |
NI
GND |
63 |
64 |
MIPI_CSI1_RD0p
PCIe_RX1p |
65 |
66 |
MIPI_CSI1_RD0n
PCIe_RX1n |
67 |
68 |
MIPI_CSI1_RD1p
GND |
69 |
70 |
MIPI_CSI1_RD1n
MIPI_CSI1_RCKp |
71 |
72 |
VCC-NGFF
MIPI_CSI1_RCKn |
73 |
74 |
VCC-NGFF
GND |
75
MIPI DSI(CN12)
BPI-M6 MIPI DSI(CN12)
CN12-P1 |
MIPI_DSI_TX1_D0n
CN12-P2 |
MIPI_DSI_TX1_D0p
CN12-P3 |
MIPI_DSI_TX1_D1n
CN12-P4 |
MIPI_DSI_TX1_D1p
CN12-P5 |
MIPI_DSI_TX1_CLKn
CN12-P6 |
MIPI_DSI_TX1_CLKp
CN12-P7 |
MIPI_DSI_TX1_D2n
CN12-P8 |
MIPI_DSI_TX1_D2p
CN12-P9 |
MIPI_DSI_TX1_D3n
CN12-P10 |
MIPI_DSI_TX1_D3p
CN12-P11 |
GND
CN12-P12 |
LCD_ADC
CN12-P13 |
GPIO2/LCD1_PWR_EN(VDDIO_1.8V)
CN12-P14 |
GPIO3/LCD1_RST(VDDIO_1.8V)
CN12-P15 |
GPIO39/LCD1_BL_PWM(VDDIO_1.8V)
CN12-P16 |
GND
CN12-P17 |
GPIO0/TP_INT(VDDIO_1.8V)
CN12-P18 |
GPIO1/TP_RST(VDDIO_1.8V)
CN12-P19 |
CN12-P20 |
CN12-P21 |
GND
CN12-P22 |
GND
CN12-P23 |
PWR_5V
CN12-P24 |
PWR_5V
Debug UART(CON2)
BPI-M6 Debug UART(CON2)
CON2-P1 |
GND
CON2-P2 |
UART0-RX
CON2-P3 |
UART0-TX
Source code on github
Armbian Source code:
Linux Source code:
- BPI-M6 VS680 SOC System Tool Manual V1.3.2.1
- Baidu Cloud: https://pan.baidu.com/s/1tX7UVSJQOcNhMlazQRQkpw?pwd=8888 (pincode:8888)
- Google Drive: https://drive.google.com/file/d/1gQalGLqNN24TeTBmJGzS0e3HeXxRD1fP/view?usp=sharing
- Baidu Cloud: https://pan.baidu.com/s/18VTAdGtQFb2nu1bku8mHBw?pwd=8888 (pincode:8888)
- Google Drive: https://drive.google.com/file/d/1z-o5dZWcYrmTqNH3Wz9ttWUzptveCS6s/view?usp=sharing
- Baidu Cloud: https://pan.baidu.com/s/1Ngc11CcnufAdDcdwMd2mmQ?pwd=8888 (pincode:8888)
- Google Drive: https://drive.google.com/file/d/1HJmpC5L3YqrJt4IsN0SMD5HoowqfGCyU/view?usp=sharing
- 2023-08-30 release aosp_dolphin_tablet-syna-image-lpddr4x
- Baidu Cloud: https://pan.baidu.com/s/1unEibD-NI8-Ti5le2E6d7g?pwd=8888 (pincode:8888)
- Google Drive:https://drive.google.com/file/d/1egPBOusdlNGJDdp5muAjiv2MvMya0F-H/view?usp=sharing
- 2024-02-29-Armbian-unofficial_24.2.0-trunk_Bananapim6_bookworm_legacy_5.4.195_xfce_desktop.img
- Baidu cloud: https://pan.baidu.com/s/1NqAxVm4XXUh95T8a7MI6lg?pwd=8888 (pincode:8888)
- Google drive:
- 2024-02-29-Armbian-unofficial_24.2.0-trunk_Bananapim6_bullseye_legacy_5.4.195_xfce_desktop.img
- Baidu cloud: https://pan.baidu.com/s/1nxF_DtdgjL5Qey9_FA3KlA?pwd=8888 (pincode:8888)
- Google drive:
- 2024-02-29-Armbian-unofficial_24.2.0-trunk_Bananapim6_bookworm_legacy_5.4.195.img
- Baidu cloud: https://pan.baidu.com/s/1cvj-rhe9ilbD6UQdxP55RQ?pwd=8888 (pincode:8888)
- Google drive:
- 2024-02-29-Armbian-unofficial_24.2.0-trunk_Bananapim6_bullseye_legacy_5.4.195.img
- Baidu cloud: https://pan.baidu.com/s/1vmSHl0Kb58Qd9m5VE8waJg?pwd=8888 (pincode:8888)
- Google drive:
- 2024-01-25-ubuntu-20.04-mate-desktop-vpu-npu-bpi-m6-aarch64-sd.img
- Baidu Cloud: https://pan.baidu.com/s/1IUDdKI0lT53-jFqUgqrdGA?pwd=8888 (pincode:8888)
- Google Drive: https://drive.google.com/file/d/1mw0Fiwa0fmXyTs6c6DI9Z4bcQZEy83p2/view?usp=sharing
