Revision as of 01:49, 20 February 2024 by Squy (talk | contribs) (Created page with "=Prepare= Ethernet cable, BPI-WiFi6, 12V power supply =Web page upgrade= 1. First, download the [https://wiki.banana-pi.org/Banana_Pi_BPI-Wifi6_Router#System_image image] you...")
Web page upgrade
1. First, download the image you want to upgrade.
2. Power on the BPI-WiFi 6 and connect it to the computer using a network cable.
3. Enter the webpage (default IP is 192.168.1.1,the user is root and does not have a password.)
File:Bpi-wifi6 upgrade 5.png
4. Select “System", then select "Backup/Flash Firmware".
File:Bpi-wifi6 upgrade 1.png
5. Select "Flash image…​".
File:Bpi-wifi6 upgrade 2.png
6. Select the image you want to upgrade, and then click "Upload".
File:Bpi-wifi6 upgrade 3.png
7. Uncheck "Keep settings and retain the current configuration".Select "Continue".
File:Bpi-wifi6 upgrade 4.png
8. Wait a few minutes, after the upgrade is completed, it will automatically restart and the web page will automatically refresh.
