Getting Started with BPI-R3 MINI
[hide]Introduction
MediaTek MT7986(Filogic 830)
- Wifi 6 2.4G/5G(MT7976C)
- 2G DDR RAM
- 8G eMMC flash
- 128MB Nand flash
- 2x 2.5GbE Ethernet port
- 1x M.2 Key B USB inerface
- 1x M.2 KEY M PCIe inerface
- 1x USB2.0 interface
* Prepare USB-Serial interface * Using your USB-Serial Connect debug console on BPI-R3 MINI Note: Debug Uart 3.3v TTL,Baud: 115200. * Default IP address for LAN port: 192.168.1.1 * User name/password: pi/bananapi ,root/bananapi. Or the user is root without a password. * WIFI: Operwrt![]()
Warnning
If there is no OS in the memory, the consol port will print "System halt!" and sotp running. At this time, you need to switch to another memory to boot from.![]()
if you want to update EMMC device, please boot from Nand![]()
otherwise you update Nand device when it boot from EMMC.![]()
Before burning image to eMMC, please prepare a USB disk. Let's take OpenWrt image (mtk-bpi-r3mini-EMMC-20230719.img, bl2_emmc-r3mini.img) for example, the steps are below:
1. Copy EMMC boot OpenWrt image(mtk-bpi-r3mini-EMMC-20230719.img, bl2_emmc.img) to USB disk. 2. Change boot switch Jumper, the board boot from Nand device, then power up the board. 3. Plug in USB disk to the board, and mount the USB to /mnt or other directory as follows: (you can skip mounting if it is mounted automatically) * mount -t vfat /dev/sda1 /mnt * change your directory to the mounting point, here is : cd /mnt
4. Execute following command to enable and copy image to EMMC device: * echo 0 > /sys/block/mmcblk0boot0/force_ro * dd if=bl2_emmc-r3mini.img of=/dev/mmcblk0boot0 * dd if=mtk-bpi-r3mini-EMMC-20230719.img of=/dev/mmcblk0 * mmc bootpart enable 1 1 /dev/mmcblk0
5. power off R3MINI board, remove u-disk driver, change bootstrap to boot from emmc device. Note: Enable EMMC device, boot strap is from EMMC.
1. Copy Nand boot OpenWrt image(mtk-bpi-r3mini-NAND-20230719-single-image.bin) to USB disk. 2. Change boot switch Jumper, the board boot from EMMC device, then power up the board. 3. Plug in USB disk to the board, and mount the USB to /mnt or other directory as follows: (you can skip mounting if it is mounted automatically) * mount -t vfat /dev/sda1 /mnt * change your directory to the mounting point, here is : cd /mnt
4. Execute following command to erase the whole Nand flash and copy image to nand device: * mtd erase /dev/mtd0 * dd if=mtk-bpi-r3mini-NAND-20230719-single-image.bin of=/dev/mtdblock0
5. power off BPI-R3 MINI board, remove u-disk driver, change bootstrap to boot from Nand device. Note: Enable Nand device, boot strap is from Nand.
Network-Configuration
root@OpenWrt:/# ifconfig
lo Link encap:Local Loopback
root@OpenWrt:/#
iperf3 test
2.5G Ethernet:
R3miniA(WAN)---| | |2.5G switch |---Ethernet R3miniB(WAN)---| | R3miniA <-------iperf3------> R3miniB![]()
R3miniA(WAN)---| | |2.5G switch |---Ethernet R3miniC(WAN)---(LAN)R3miniB(WAN)---| | R3miniC <-------iperf3------> R3miniA![]()
5GWi-Fi:
iPhone 5Gwifi <-------iperf3------> (Wi-Fi) BPI-R3mini Note: The distance between iPhone and R3mini is about one meter.![]()
FAN
- CN16 is a 1.25 pitch 3PIN socket, used to connect the fan, supports PWM control.
PWM FAN Control
M.2 KEY B slot
currently, M.2 KEY B slot only support USB 4G/5G module, example: Quectel RM500U-CN or RM520N-GL
when you install one 4G/5G module, you may check it.
4G/5G Module
BPI-R3mini supports M.2 KEYB USB interface Cellular network module: 4G LTE EM05, 5G Quectel RM500U-CN/RG200U-CN and RM520N-GL/RM500Q-GL Series.
The released image(2023-11-15 or later) default driver is RM500U-CN and RM520N-GL, Install one of these two modules and you can use it directly.
If use EM05 or others,you will most likely need to modify the driver.
- 1. Install 4G/5G Cellular Module into CN4 Slot(M.2 KEYB)
- 2. Inset the NANOSIM Card
- 3. Install antenna on the module
- 4. After powering on, it will automatically dial
RM520N-GL wwan0 Link encap:Ethernet HWaddr C2:CA:76:42:83:EC NOARP MTU:1500 Metric:1 RX packets:0 errors:0 dropped:0 overruns:0 frame:0 TX packets:0 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1000 RX bytes:0 (0.0 B) TX bytes:0 (0.0 B) wwan0_1 Link encap:Ethernet HWaddr C2:CA:76:42:83:EC NOARP MTU:1500 Metric:1 RX packets:0 errors:0 dropped:0 overruns:0 frame:0 TX packets:0 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1000 RX bytes:0 (0.0 B) TX bytes:0 (0.0 B) root@OpenWrt:/# root@OpenWrt:/# lsusb Bus 001 Device 001: ID 1d6b:0002 Linux 5.4.188 xhci-hcd xHCI Host Controller Bus 002 Device 002: ID 2c7c:0801 Quectel RM520N-GL Bus 002 Device 001: ID 1d6b:0003 Linux 5.4.188 xhci-hcd xHCI Host Controller root@OpenWrt:/# root@OpenWrt:/# ping ping baidu .com PING baidu.com (110.242.68.66) 56 data bvtes 64 bytes from 110.242.68.66: seq=0 ttl=50 time=38.540 ms 64 bytes from 110.242.68.66: seq=1 ttl=50 time=38.276 ms 64 bytes from 110.242.68.66: seq=2 ttl=50 time=38.355 ms 64 bytes from 110.242.68.66: seq=3 ttl=50 time=38.788 ms ^C --- baidu.com ping statistics --- 4 packets transmitted, 4 received,0% packet loss round-trip min/avg/max = 38.276/38.490/38.788 ms root@OpenWrt:/#
RM500U-CN usb0 Link encap:Ethernet HWaddr 46:F7:1B:36:AE:26 inet addr:10.101.26.65 Bcast:10.101.26.255 Mask:255.255.255.0 inet6 addr: 2409:895a:30a9:55e2:44f7:1bff:fe36:ae26/64 Scope:Global inet6 addr: fe80::5c3b:9cff:fe76:7c46/64 Scope:Link UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1 RX packets:191 errors:0 dropped:2 overruns:0 frame:0 TX packets:243 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1000 RX bytes:71800 (70.1 KiB) TX bytes:35923 (35.0 KiB) root@R3mini-Router:/# root@R3mini-Router:/# lsusb Bus 001 Device 001: ID 1d6b:0002 Linux 5.4.171 xhci-hcd xHCI Host Controller Bus 002 Device 002: ID 2c7c:0900 RM500U-CN Bus 002 Device 001: ID 1d6b:0003 Linux 5.4.171 xhci-hcd xHCI Host Controller root@R3mini-Router:/#
Wi-Fi Ap mode on BPI-R3mini
- ra0 is MT7986a 2.4G wifi
- rax0 is MT7986a 5G wifi
Serial cable
Because the UART0_TXD of the debug port is also a wifi strap pin, this pin needs to be pull-low when poweron,
some serial cable have strong pull-up, such as PL2303,if it is inserted before powering on, it will cause the wifi chip to be recognized incorrectly, and the wifi function will fail.
Other types including cp2102,ch340 and FDTI are all available, serial cable power domian must be 3.3v TTL standard.
You can buy the serial cable here: https://www.aliexpress.us/item/3256805457599756.html?
If your computer has a USB TypeC connector and supports PD12V/1.5A (20W) or above, you can also directly use the computer to power BPI-R3mini.
Moreover, since BPI-R3mini has built-in USB to serial port chip CH340E, you do not need to use additional serial cables.
NOTE:If your computer does not support USB PD, then the R3mini will most likely keep restarting.
Because the power consumption of R3mini is relatively large (all peripherals are plugged in and the power consumption is close to 20W when running)
TTL Voltage
- The debug uart is 3.3V TTL power domain.
