Getting Started with BPI-M4 Berry
![](/images/thumb/a/a6/Banana_Pi_BPI-M4_Berry_1.jpg/300x225x300px-Banana_Pi_BPI-M4_Berry_1.jpg.pagespeed.ic.RUYpd3zj9g.jpg)
![](/images/thumb/2/29/Banana_pi_BPI-M2_Berry_5.JPG/300x225x300px-Banana_pi_BPI-M2_Berry_5.JPG.pagespeed.ic.1M7S9SeJtL.jpg)
![](/images/thumb/a/a9/BPI-M2_Pro_2.jpg/300x225x300px-BPI-M2_Pro_2.jpg.pagespeed.ic.QwYAEL6-Jj.jpg)
![](/images/thumb/6/6e/Banana_Pi_BPI-M2S_1.jpg/300x225x300px-Banana_Pi_BPI-M2S_1.jpg.pagespeed.ic.09oBHwAysc.jpg)
![](/images/thumb/7/7b/Banana_Pi_BPI-M5_1.JPG/300x225x300px-Banana_Pi_BPI-M5_1.JPG.pagespeed.ic.gFvwugqKO7.jpg)
- 1 Development
- 1.1 Android
- 1.2 Linux
- 1.2.1 Prepare
- 1.2.2 Install Image to SDcard
- 1.2.3 Install Image to eMMC
- 1.2.4 Erase eMMC
- 1.2.5 Ubuntu Desktop
- 1.2.6 Debug UART
- 1.2.7 SSH
- 1.2.8 NoMachine Remote Desktop
- 1.2.9 WiFi
- 1.2.10 Set static IP, DNS
- 1.2.11 Network time synchronization
- 1.2.12 View hardware temperature
- 1.2.13 Modify HDMI output resolution
- 1.2.14 Use USB disk
- 1.2.15 Use Audio Devices
- 1.2.16 Use Bluetooth
- 1.2.17 Use IR Receiver
- 1.2.18 Transfer files
- 1.2.19 40 pin interface GPIO, I2C, UART, SPI, and PWM testing
- 1. Download latest Android image.
- 2. Download and Install Allwinner Image Download Tools, PhoenixSuit is for window.
- 3. Type-C cable, 5V power supply.
Install Image with USB tool
- 1. Open PhoenixSuit, click the Firmware icon to switching to firmware download panel, then click Image button and choose the Android Image file.
- 2. Press and hold the SW2 button on M4 Berry while connecting to the computer using type-c, popup a warning dialog.Press Yes.
- 3. Download
- 4. Download finish
Custom IR
- Wiki images support NEC protocol default.
- 1. Execute getevent -l | grep MSC_SCAN in the serial port or adb shell, then press the corresponding button on the remote control to obtain the device ID and scancode.
- The MSC_SCAN data is 32 bits.
- Bits [31:24] represent the key press status, where 0 indicates release, and 1 indicates press.
- Bits [23:8] represent the device ID. Use this ID to generate a keylayout file named customer_ir_xxxx.kl. For example, in this case, it would be customer_ir_fe01.kl.
- Bits [7:0] represent the scancode.
- 2. Based on the results of step one, create a new file named customer_ir_xxxx.kl with the following content:
- Map the scancodes in the second column to Android keycodes.
- 3. Use the adb command to push customer_ir_xxxx.kl to the system.
$ adb root $ adb remount $ adb push customer_ir_xxxx.kl /system/usr/keylayout/ $ adb reboot
- For source code porting, put the customer_ir_xxxx.kl to vendor/w/common/hardware/input/multi_ir/keylayout/ directory and build the source code.
Custom Logo
- 1. Boot logo
- Rename the logo file to bootlogo.bmp and put it in longan/device/config/chips/h618/boot-resource/boot-resource/ directory.
- 2. Bootanimation logo
- Put bootanimation.zip to device/softwinner/apollo/common/media/bootanimation/ directory.
- 3. Launcher logo for Box variant image
- Create a 270x110, 32 bit depth, png image and rename it to aw_logo.png, put it in vendor/aw/common/package/TVLauncher/res/drawable-xhdpi/ directory.
- Then build the source code and flash the image to your board.
- 1. Linux image support SDcard or EMMC bootup, and will boot from the SD card first.
- 3. Make sure bootable EMMC is formatted if you want bootup from SDcard.
- 5. Download latest bananapi ubuntu/debian images, and confirm that the md5 checksum is correct.
- 7. The wiki guide is only for bananapi ubuntu/debian images.
- 8. USB-Serial (3.3V). Baud: 115200.
sudo bananapi-config
Erase eMMC
pi@bpi-m4berry:~$ lsblk NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINTS mmcblk0 179:0 0 7.4G 0 disk └─mmcblk0p1 179:1 0 7.2G 0 part /var/log.hdd / mmcblk1 179:32 0 7.3G 0 disk └─mmcblk1p1 179:33 0 7.3G 0 part mmcblk1boot0 179:64 0 4M 1 disk mmcblk1boot1 179:96 0 4M 1 disk zram0 252:0 0 993.2M 0 disk [SWAP] zram1 252:1 0 50M 0 disk /var/log zram2 252:2 0 0B 0 disk
Ubuntu Desktop
- 1. Using the Ubuntu desktop version system image, you can get a graphical operation interface.
- 2. You need to prepare a monitor with an HDMI interface and an HDMI cable.
- 3. Use an HDMI cable to connect the monitor and BPI-M4 Berry, switch the monitor input interface to the corresponding HDMI interface, power on, and wait a moment to see the desktop.
Debug UART
- 1. Prepare a 3.3v USB to TTL module.
- 2. Use the USB to TTL module to connect the PC USB port and the Debug UART port on the board.
- 3. Open a serial terminal software on the PC, such as mobaxterm or putty.
- 4. Taking mobaxterm as an example, after setting the serial port number and 115200 baud rate, you can open the BPI-M4 Berry UART terminal.
SSH
- 1. Prepare a network cable and a router.
- 2. Use a network cable to connect the LAN port of the router to the BPI-M4 Berry, and also connect the PC to another LAN port.
- 3. Check the IP address of BPI-M4 Berry on the router management interface, or use the following command on the BPI-M4 Berry UART terminal to check the IP address.
ifconfig
eth0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500 inet 192.168.3.10 netmask 255.255.255.0 broadcast 192.168.3.255 inet6 fe80::3e1f:688f:81ab:d8b7 prefixlen 64 scopeid 0x20<link> ether 02:00:54:a0:d6:a6 txqueuelen 1000 (Ethernet) RX packets 553 bytes 92549 (92.5 KB) RX errors 0 dropped 0 overruns 0 frame 0 TX packets 329 bytes 26023 (26.0 KB) TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0 device interrupt 42
- 4. Open an SSH terminal software on the PC, such as mobaxterm or putty.
- 5. Taking mobaxterm as an example, fill in the obtained IP address, such as 192.168.3.10 above, in the IP address column and 22 in the Port port.
- 6. Open the SSH terminal and enter the login username/password: pi/bananapi or root/bananapi. There will be no prompt when entering the password. Please enter it normally and press Enter when finished.
- 1. Make sure BPI-M4 Berry is connected to the Internet and use the following command to download the nomachine DEB installation package in the system.
- 2. Or open NoMachine for ARM - arm64 download page in a PC browser, download the DEB installation package, and then copy it to BPI-M4 Berry user directory through SSH or USB disk.
- 3. After the download is completed, install it through the following command. Note that the file name is based on the actual downloaded file name.
- 4. PC side also needs to download and install NoMachine. NoMachine download page Select the installation package suitable for the PC operating system, download it locally and complete the installation.
- 5. Pay attention to keeping the PC and BPI-M4 Berry in the same LAN. You can try SSH connection first to ensure normal communication within the LAN.
- 6. Open NoMachine on the PC, click the Add button, enter the IP address of BPI-M4 Berry in the Host bar in the window after the jump, and then click the Add button.
- 7. Click the recognized port icon, enter the username/password in the new window that pops up, and then click the OK button.
- 8. After completing the subsequent settings, you can see the desktop.
- 9. If no device is connected to the HDMI interface, the NoMachine remote desktop will display a black screen. It is recommended to keep the HDMI connection or connect an HDMI decoy device.
WiFi
- Use the nmcli command to scan WiFi hotspots, connect to hotspots, and create AP hotspots.
nmcli device #List devices nmcli device wifi list # List available wifi access points, list can be omitted nmcli device wifi connect [SSID] password [PASSWORD] # Connect to the hotspot mySSID. After the connection is successful, the configuration file will be automatically generated. If you want to connect again in the future, you can use the nmcli connection up [SSID] command. nmcli device disconnect [device name] # Disconnect wifi, use the wifi device name displayed in the nmcli device command nmcli device wifi hotspot con-name [NAME] ifname [device name] ssid [SSID] password [PASSWORD] # Create AP hotspot
nmcli connection show #List network connection configuration nmcli connection down [NAME] # Deactivate a connection nmcli connection up [NAME] # Activate a connection nmcli connection delete [SSID] #Delete a configuration and no longer save information and automatically connect
nmcli radio wifi off # Turn off wifi nmcli radio wifi on # Turn on wifi
Set static IP, DNS
- 1. To set a static IP, you need to maintain the connection first. If you want to set an Ethernet static IP, you must first maintain the Ethernet connection; if you want to set a wireless network static IP, you must first maintain a connection to a WIFI.
- 2. If the upper-level router has assigned the IP address you want to set to other devices, please change it to an idle IP, or ask other devices to give up the IP.
- 3. Use the nmcli connection show command to display all connections, for example:
- 4. Use the nmcli connection show [NAME] command to display all the properties of a specific connection, such as:
#Only list three common items ipv4.dns: 192.168.3.1 #The default is the gateway address ipv4.addresses: 192.168.3.10/24 #The default is the IP address assigned by the router DHCP ipv4.gateway: 192.168.3.1 #Gateway address, the default is the IP address of the router
- 5.Set static IP:
- 6.Set DNS:
- 7.Reset:
reboot
- 8. After restarting, check whether the modification is successful:
- Chrony is an open source free Network Time Protocol NTP client and server software. It allows the computer to keep the system clock synchronized with the clock server (NTP), thus allowing your computer to maintain accurate time. Chrony can also be used as a server software to provide time synchronization services for other computers.
sudo apt install chrony #Install chrony systemctl start chrony #Start chrony systemctl enable chrony systemctl status chrony systemctl restart chrony #Restart service
timedatectl status #View time synchronization status timedatectl list-timezones #View time zone list timedatectl set-timezone Asia/Shanghai #Modify time zone timedatectl set-ntp true #Enable NTP network time synchronization
date #View time sudo hwclock -r #View hardware clock
sensors
- When using the Ubuntu desktop operating system, you can find the Displays column in Settings and modify the resolution.
Use USB disk
- 1. Prepare a USB disk that has been partitioned normally and insert it into the USB interface of BPI-M4 Berry.
- 2. In the Ubuntu desktop version, you can see that the USB disk has been recognized and can be opened in the file manager, or partition management can be performed through the GParted tool.
- 3. In the terminal, mount the USB disk to the local directory:
mkdir mnt #Create a separate directory in the ~/user directory for mounting for easy management cat /proc/partitions | grep "sd*" #List partitions starting with sd sudo mount /dev/sda1 ~/mnt/ #Mount /dev/sda1 to ~/mnt/ ls ~/mnt/ #After mounting, you can list the files in the USB disk sudo umount -v /dev/sda1 #umount, then you can remove the USB disk
Use Audio Devices
- Prepare an audio file and copy it to the BPI-M4 Berry Ubuntu desktop system through a USB flash drive or SSH.
HDMI audio
- 1. Prepare a monitor with HDMI audio input function, turn on the relevant functions in the monitor settings, and use an HDMI cable to connect the monitor.
- 2. Set the output device to HDMI Audio in the Sound column of the settings.
- 3.Play audio.
3.5mm audio jack
- 1. Prepare a headset or other audio device that uses a 3.5mm plug, insert the plug into the 3.5mm jack of BPI-M4 Berry.
- 2. Set the output device to Audio Codec in the Sound column of the settings.
- 3. Play audio.
aplay -l #List devices aplay -D hw:0,0 [path] #Play the audio file of the specified path
Use Bluetooth
- 1. Open settings in the Ubuntu desktop and connect a Bluetooth device, such as a Bluetooth mouse or keyboard, in the Bluetooth bar.
- 2. The method to connect the Bluetooth device through the command line in the terminal is as follows:
pi@bpi-m4berry:~$ sudo bluetoothctl #Open the Bluetooth device management tool [sudo] password for pi: Agent registered [CHG] Controller 2C:C3:E6:AC:D5:D8 Pairable: yes [bluetooth]# power on #Start the Bluetooth function, power off to turn it off Changing power on succeeded [bluetooth]# discoverable on #Allow this device to be discovered Changing discoverable on succeeded [CHG] Controller 2C:C3:E6:AC:D5:D8 Discoverable: yes [bluetooth]# pairable on #Allow device pairing Changing pairable on succeeded [bluetooth]# scan on #Start scanning Discovery started [CHG] Controller 2C:C3:E6:AC:D5:D8 Discovering: yes [NEW] Device D4:C4:85:A5:C6:B1 Logitech Pebble #The MAC address and device name of a Bluetooth mouse [CHG] Device D4:C4:85:A5:C6:B1 TxPower: 4 [bluetooth]# pair D4:C4:85:A5:C6:B1 #Pair the MAC address of the Bluetooth device you want to connect to Attempting to pair with D4:C4:85:A5:C6:B1 [CHG] Device D4:C4:85:A5:C6:B1 Connected: yes [DEL] Device A4:C1:38:9B:F6:FD SLPO20N20200059 [CHG] Device D4:C4:85:A5:C6:B1 UUIDs: 00001800-0000-1000-8000-00805f9b34fb [CHG] Device D4:C4:85:A5:C6:B1 UUIDs: 00001801-0000-1000-8000-00805f9b34fb [CHG] Device D4:C4:85:A5:C6:B1 UUIDs: 0000180a-0000-1000-8000-00805f9b34fb [CHG] Device D4:C4:85:A5:C6:B1 UUIDs: 0000180f-0000-1000-8000-00805f9b34fb [CHG] Device D4:C4:85:A5:C6:B1 UUIDs: 00001812-0000-1000-8000-00805f9b34fb [CHG] Device D4:C4:85:A5:C6:B1 UUIDs: 00010000-0000-1000-8000-011f2000046d [CHG] Device D4:C4:85:A5:C6:B1 ServicesResolved: yes [CHG] Device D4:C4:85:A5:C6:B1 Paired: yes Pairing successful #pairing successfully [CHG] Device D4:C4:85:A5:C6:B1 Modalias: usb:v046DpB021d0007 [bluetooth]# exit #Exit the Bluetooth device management tool pi@bpi-m4berry:~$
Use IR Receiver
- 1. You need to prepare an infrared remote control using NEC format.
- 2. Enter the following command in the terminal to start receiving infrared signals.
sudo ir-keytable -c -p NEC -t
Transfer files
scp
The scp command format is:
- 1.[optionals] is an optional parameter, such as -r, which can be used to copy the entire directory recursively.
- 2.file_source The file or directory to be copied.
- 3.file_target will copy the past path and rename it if a specific file name is entered at the end.
PS D:\temp\temp_4> scp ".\hello.txt" [email protected]:"/home/pi/Downloads/"
PS D:\temp\temp_4> scp [email protected]:"/home/pi/Downloads/hello.txt" "D:\temp\temp_4"
- Where [email protected] is the user name in the Linux system and the IP address of the BPI-M4 Berry in the LAN.
- Where :"/home/pi/Downloads/hello.txt" is the file path in the Linux system.
- Where "D:\temp\temp_4" is the path in Windows system.
mobaxterm
GPIO
- 1.Execute
gpio mode 2 out
- to set it to output mode.
- 2.Execute
gpio write 2 1
- 3.Execute
gpio write 2 0
- 1.Firstly, it is necessary to set the GPIO port to input mode
gpio mode 2 in
- 2.Then set the GPIO port as an pull-up resistor
gpio mode 2 up
- 3.Finally, set the GPIO port to dropdown mode
gpio mode 2 down
I2C
- 1.Execute
- 4.Use the keyboard directional keys to move, then use the spacebar to select.Select "pg-i2c3"and"pg-i2c4"
- 7.After restarting, check if there are i2c-3 and i2c-4 nodes.
pi@bpi-m4berry:~$ ls /dev/i2c-3 /dev/i2c-3 pi@bpi-m4berry:~$ ls /dev/i2c-4 /dev/i2c-4
- 8. Execute
cd /usr/src/wiringPi/examples/ gcc ./oled_demo.c -o oled -lwiringPi
- 9.Connect the i2c device to the pin of i2c3. Execute
sudo ./oled /dev/i2c-3
- 10.Connect the i2c device to the pin of i2c4. Execute
sudo ./oled /dev/i2c-4
UART
- 1.Uart1 and Uart5 is closed by default and needs to be opened. Execute
- 4.Use the keyboard directional keys to move, then use the spacebar to select.If you want to use uart1,select"pg-uart1".If you want to use uart5,select"ph-uart5"
- 7.After restarting, check if there are ttyS5 nodes.
pi@bpi-m4berry:~$ ls /dev/ttyS5 /dev/ttyS5
- 8:Short circuit uart1 pin or uart5 and execute
gpio serial /dev/ttyS1
SPI
- 1.Execute
- 4.Use the keyboard directional keys to move, then use the spacebar to select.Select "spi1-cs1-spidev"
- 7.After restarting, check if there are SPI nodes.
pi@bpi-m4berry:~$ ls /dev/spidev1.1 /dev/spidev1.1
- 8.Execute
- It can be seen that TX and RX are different. So, we need to short-circuit MOSI and MISO and execute the command again.
