Getting Started with R2
Revision as of 20:21, 14 May 2018 by JackZengWiki (talk | contribs)
Read more: Banana Pi BPI-R2
- Mali 450 MP4 GPU
- 2G DDR3 SDRAM
- 1x Mini PCIE interface
- 2x SATA interface
BPI-R2 SATA interface
- Note:
1.Prepare 16G/above TF card, USB-Serial interface, Ubuntu System
2.Using your USB-Serial Connect debug console on R2
Load your first image on R2
1.You could download latest image from our forum * Here is the example image link: http://forum.banana-pi.org/t/bpi-r2-new-image-release-ubuntu-16-04-v1-3-2018-3-30/5293
2.Install bpi-tools on your Ubuntu * apt-get install pv * curl -sL https://github.com/BPI-SINOVOIP/bpi-tools/raw/master/bpi-tools | sudo -E bash
Build your own image on R2
1. Clone Bsp project from Github * Execute "git clone [email protected]:BPI-SINOVOIP/BPI-R2-bsp.git"
5. If you want to install Ubuntu on EMMC, follow these steps: * Program ubuntu image to SD card * Install this SD to R2 board and boot from SD * Enter the Uboot prompt, and run command emmc pconf 48 to change Partition config of EMMC * And then run command reset, let it boot to OS * Enter the system with username pi or root * Run command echo 0 > /sys/block/mmcblk1boot0/force_ro to enable /dev/mmcblk1boot0 write mode` * To write preloader to EMMC by running command: "bpi-bootsel BPI-R2-EMMC-boot0-DDR1600-0k-0905.img.gz /dev/mmcblk1boot0" where BPI-R2-EMMC-boot0-DDR1600-0k-0905.img.gz is the preloader for emmc, please download it from link:https://github.com/BPI-SINOVOIP/BPI-files/blob/master/SD/100MB/BPI-R2-EMMC-boot0-DDR1600-0k-0905.img.gz
* To copy ubuntu image to EMMC: unzip -p <XXX.img.zip> | pv | dd of=<device> bs=10M status=noxfer or bpi-copy <XXX.img.zip> <device> where the XXX.img.zip is ubuntu image we can get it from http://www.banana-pi.org/r2-download.html 40, and where should be /dev/mmcblk1. * power off * remove SD & power on
OpenWrt
1. Clone OpenWrt project from Github. * Execute "git clone https://github.com/garywangcn/bpi-r2_lede.git"
4. Use "make menuconfig" to configure your image. * Choose "Target System" to config as "MediaTek Ralink ARM" * Choose "Boot Loaders" to config as "u-boot-bpi_r2"
you will find two images:
* mtk-bpi-r2-EMMC.img
* mtk-bpi-r2-SD.img
* Change the Partition configurion of EMMC is 48h: reboot the system which is running SD, and enter the U-boot command line, run command emmc pconf 48 (for this steps, we can change partition configuration in userspace by using mmc-utils,see more information in BPI-R2 OpenWrt(LEDE) Souce code : 2018-04-11)
7. This step is for upgrade, if you don't want to install image after you built, you could use runtime upgrade. * Copy "bin/targets/mediatek/32/lede-mediatek-32-bananapi,bpi-r2-sysupgrade.tar" to R2 board which is running OpenWrt system(no matter where(SD or EMMC) it boots from), and then run command "sysupgrade lede-mediatek-32-bananapi,bpi-r2-sysupgrade.tar" to update both kernel and rootfs.
GPIO
PWM Control
Develop 4G module with R2
Gets more info from here:
WiFi and Ap mode on R2
- wmt_loader (ignore errors)
- network={ ssid=“ssid” psk=“password” priority=1}
AP mode
- echo A >/dev/wmtWifi
- And a bridge
- brctl addbr br0
- brctl addif br0 ap0
- brctl addif br wan
Make your own image
- Prepare a SD card which have installed Ubuntu system.
- Boot your SD card with R2, after R2 finish starting, copy your files and config your Ubuntu, then poweroff R2.
- Plug your SD card in Linux PC, "cd /media", then "ln -s <your account> pi".
- Execute "bpi-migrate -c bpi-r2.conf -c ubuntu-mate-from-sd.conf -d /dev/sdb".
- Then you could get your own image now.
Install image on EMMC
Release
Ubuntu with kernel 4.4
- BPI-R2 Ubuntu 16.04 Kernel4.4 V1.3: http://forum.banana-pi.org/t/topic/5293
Ubuntu with kernel 4.14
OpenWrt(LEDE)
Centos 7
